Old 07-26-2010, 10:31 PM   #1
Nerk
Nerk's Avatar
E30 Timing belt tensioner spring
Hey,
A quick question, we just did a timing belt change on my buddy's 1987 325(E) and noticed that the tensioner spring is not there... at first I thought the last guy that changed the belt didn't use the tensioner spring, so I was planning on grabbing it from a 1985 325E that I'm parting out, so I took the cover off and... guess what... no spring...
is it possible that the spring is only in select models? I haven't done the work on my 325IS yet, so I'm not sure with the "I" engines if its different or not...
also, how tight should this belt be, we did it as tight as possible, and there was still a little bit of play, but someone at work today said that was a bad idea, and the belt should be on the looser side....
Let me know, kind of confused by all this, and this is my first time doing the job. I'm sure it won't be last
Thanks,
Old 07-26-2010, 10:40 PM   #2
Ceeker
Originally Posted by Nerk View Post
Hey,
Thanks,
If the belt is too loose you could skip a tooth and either jump the belt one tooth or strip the tooth - either way it will result in throwing your timing off and bending a few valves. timing belt or not it should have a working tensioner and spring.
Doesn't matter which model if it's an e30 and a 6 cyl you should have a tensioner spring. the rule of thumb is the belt should be able to turn 90 degrees with your thumb and finger. If it doesn't then it may be too tight which can result in premature wear, if too loose then the above can happen.
2 IX's -sold and parts
2 325i 4 dr - sold
1 87 325is red - parts
1 89 325i vert grey - parts
1 90 325is white - keepin
1 87 325i vert -red - keepin
Ceeker is online now   Reply With Quote
Old 07-26-2010, 11:54 PM   #3
davericher20
black and blue
davericher20's Avatar
get the spring. when the po or mechanic did it last it probably flew off and they said f-it when they couldn't find it and set the tension themselves.
Go get one.
1989 325 IX Touring
Tags
tensioner spring, timing belt
