Old 07-21-2010, 06:16 PM   #16
e30_kid89
The Afro-stig
e30_kid89's Avatar
What turbo are you using? If it's not a ball bearing ditch the restrictor.
If its still leaking/smoking with the CCV vented to atmosphere and a proper oil feed/drain then the seals are shot.
Old 07-21-2010, 06:32 PM   #17
jamison67
E30 POWER
jamison67's Avatar
its a ebay turbo ,,,,so i think the ebay turbos r ball bearing ,,correct me if im wrong...
and ill be honest i didnt really listin when i was told not to buy this and if the seals r shot ill be doin a 3 pointer wit this turbo right into the garbage,,and will be buyin a holset
any ways heres some pics ,,,im goin to get more but heres a few for now
http://s910.photobucket.com/albums/a.../turbo%20pics/
jamison67 is offline   Reply With Quote
Old 07-21-2010, 06:52 PM   #18
e30_kid89
The Afro-stig
e30_kid89's Avatar
http://s910.photobucket.com/albums/a...bo%20pics/
ah, there's your problem, ebay turbo. The seals are probably shot. They're not ball bearing.
Do yourself a favor and hit up ebay, not for more ebay china chargers You can probably find a decent or even new rebuilt Holsets for 200-400 bones which is a bargain. plus they are indestructible if taken care of.
an H1C or an HX35 is what you want.
Old 07-21-2010, 07:17 PM   #19
I think it would make more sense to put your AFM before the turbo.
It would make even more sense to convert to a standalone EMS so you can ditch the AFM... that's what I'm going to be doing very soon.
Old 07-21-2010, 07:29 PM   #20
jamison67
E30 POWER
jamison67's Avatar
ya thats the plan of ditching the afm and going standalone,,,e30kidd got me convinced,,,,,i just got to wait a bit as things r a little tight rite now...i just wanna get this thing going for the ending of this summer just to feel a little bit of what FI feels like then over the winter ill buy a holset turbo and 55 pin pnp standalone
Old 07-21-2010, 07:29 PM   #21
jamison67
E30 POWER
jamison67's Avatar
whats the didference of puting the afm in frt of the turbo as to how i have it set up now
Old 07-21-2010, 08:02 PM   #22
bmwconnect
BMW Tuner
bmwconnect's Avatar
The difference is how the stock ecu will handle the incoming air temp and the pressure waves on the barn door . I have tuned both types and both setups have disadvantages and advantages.. In a ideal world you would want the air temp sensor after the intercooler and the barn door flapper before the turbo but of course it's not easy to separate them... When the stock motronic is tuned correctly it will handle bigger injectors and boost with out any problems no matter what way you run the AFM
Old 07-21-2010, 08:10 PM   #23
e30_kid89
The Afro-stig
e30_kid89's Avatar
Hey you tune the stock motronic right? Any chance you've gotten the ignition tables from the 179ecu?
Old 07-21-2010, 08:11 PM   #24
bmwconnect
BMW Tuner
bmwconnect's Avatar
Yes shoot me a email
Old 07-21-2010, 08:20 PM   #25
The AFM is designed to work under atmospheric conditions, as soon as you have boost the door in the AFM is just going to be pegged open. The car will still run with the AFM down stream from the turbo (my car is currently set-up that way for the time being). It just makes more sense to me to have it before the turbo
edit: plus what bmwconnect said
Old 07-21-2010, 08:35 PM   #26
bmwconnect
BMW Tuner
bmwconnect's Avatar
The only real problem I ever had with my push threw setup is heat soaking the AFM and lean idle start but editing the software changed that quickly.
Old 07-21-2010, 08:44 PM   #27
So you never found that the door maxed out when under boost? because I could see that happening very easily.
Old 07-21-2010, 08:45 PM   #28
e30_kid89
The Afro-stig
e30_kid89's Avatar
pm'd
Old 07-21-2010, 08:57 PM   #29
bmwconnect
BMW Tuner
bmwconnect's Avatar
Yes all the time, but only in boost and in that situation the throttle is open more then 50%-75% or even close to wot so you just treat the high load pt map like a wot map
Old 07-21-2010, 09:06 PM   #30
Makes sense. Not ideal but that should work relatively well. I'm guessing Alpina did something similar with their old turbo motors.
