Old 07-28-2010, 11:28 AM   #16
three28
three28's Avatar
If your wheels were indeed 8.5 +48 they would hit the struts. Also, you're likely running a 235/40 which will always rub on an E36 - it's too tall.
sorry, I meant 38
three28 is offline   Reply With Quote
Old 07-28-2010, 12:14 PM   #17
Originally Posted by iverson03tj View Post
17x8 but i measured 8.5... imma look at the offset tommorow when im taking off the rims...
The wheel isn't really wide enough to support a 255. I mean if you have the tires already go ahead and use them, but it's not optimum and will bubble out a bit.
Old 07-28-2010, 04:55 PM   #18
iverson03tj
iverson03tj's Avatar
Its +38 offset btw..... will the tires rub on the suspension or the quarter panel...
Old 07-28-2010, 05:03 PM   #19
It will rub, on the quarters. 245/40 maximum.
Old 07-29-2010, 12:25 AM   #20
iverson03tj
ok thanks for the help guys!
Old 08-03-2010, 01:41 AM   #21
iverson03tj
Ok i got mine mounted.... and with rolled fenders there was no problem... for 17x8 et38.... its not rubbing anywhere... btw i do have stock springs...
