Old 07-14-2010, 12:21 AM   #1
iverson03tj
Spal Puller Fan Hook up
Hey guys i got a spal fan, and im wonderinf how do i hook it up so that it turns on when the car reaches a certain temp....
I got a spal puller fan, 16 inch, medium profile and curved blades.....
Im really not good with electricals, mostly cuz i hate dealing with it, so i kinda stray away from it... what are my options, what can i do and how do i do it... im looking for the cheapest way and parts i can find locally, nothing from the states.... duty fees suck..
Any help will be much appreciated.
Old 07-14-2010, 09:47 AM   #2
sb_600
sb_600's Avatar
I'm assuming you got the relay and wiring kit with it as well?
http://forums.bimmerforums.com/forum...light=SPAL+DIY
This basically shows you how to wire up the relay kit, and tap into the auxilary fan for the temp switch.
Good luck! I installed mine over the winter and have had no problems by following this DIY
Shawn
Shawn
sb_600 is online now   Reply With Quote
Old 07-14-2010, 10:15 AM   #3
iverson03tj
Shawn
I didnt get a relay kit with it, all i got was the fan....
and i dont get it.. the spal fan only has two wires? is the speed controlled by the voltage?
I know its easier just to make it run all the time... but is that good for the engine??
Old 07-14-2010, 10:26 AM   #4
sb_600
sb_600's Avatar
Ok - I'd suggest getting this then:
http://store.bimmerworld.com/spal-fa...kits-p560.aspx
Just get the basic kit and hook up to the aux fan.
If you want to save on duty fees, contact Arek from 8-Legs Racing - he's a Canadian Bimmerworld distributor here in Ottawa, but he can ship to you I'm sure. His screenname is ScotcH on the board. Tell him I sent you.
Good luck!
Shawn
Shawn
