Go Back   maXbimmer Forums > Specific Regional Topics > Quebec/Gatineau/Ottawa > Quebec/Gatineau/Ottawa Classifieds **NEW** > Other
Old 07-13-2010, 12:11 PM   #1
Nascar318is
Nascar318is's Avatar
Jl Audio Class D Amp 500/1 W/Sub In Box and Dual Fuse Box
Great starting kit for someone who wants a sound system with some punch. Just grab some RCA cables and go! Amp is clean and has minimal cosmetic scratches.
I sold the car it was in and no longer need it.
Here is what you get!
1 year old JL Audio 500/1 Class D series Amp($650)
Comes with the optional RBC-1 (Remote Bass Control,) ($60)
1 10" Pioneer 400W Subwoofer in Box ($300)
Stinger Dual Fuse Box For multiple amps With Battery Wire($70 W/fuse)
I paid over $1000 for this set up.
Amp Features:
Differential-Balanced Input Topology: (1 pair of Inputs)
On-board Crossover: fully variable (40Hz - 200Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (independent active filter, parallel with amp filter or full-range)
Bass EQ: parametric with variable boost up to 15dB and Remote Bass Control (optional)
Infrasonic Filter: fully-variable 24dB/octave from 15-60Hz
Signal-Sensing Turn-On: permits operation without remote lead
Dual Mono Speaker output connections: accepts up to 8ga. wire
+12V and Ground connections: accepts up to 4ga. wire
Specifications:
Rated Power: 500W RMS @ 1.5 ohm-4 ohm
(11V-14.5V)
THD at Rated Power: <0.05% @ 4 ohm
S/N Ratio: >95dB below rated power
Frequency Response: 5 Hz-500Hz (+0, -1dB)
Damping Factor: >500 @ 4 ohm per channel/50 Hz
Input Range: switchable from 200mV-2V RMS
to 800mV-8V RMS
Dimensions: 13.4"L x 9.25"W x 2.36"H
Remote Bass Connection Specs:
Without a connected RBC-1, the "Bass Boost" switch activates a +6dB boost centered at 48 Hz.
A connection for a Remote Bass Control allows fully variable boost control (0 to +15dB).
$300 open to offers..
Old 07-14-2010, 02:48 AM   #2
Bump for a good guy, even though he went all ****er and sold his BMW.
Old 07-15-2010, 03:05 PM   #3
carjoe
carjoe's Avatar
Someone should kick him in the nuts.
93 325is - sold!
2000 540ia- sold!
Old 07-15-2010, 09:12 PM   #4
Nascar318is
I love you too Joey!!
Will throw in a 2nd box with no sub..
Old 07-30-2010, 06:04 PM   #5
Nascar318is
Sold thanks!!
Tags
amp, for sale, jl audio, sound system
