Old 07-07-2010, 05:03 PM   #1
be30318i
E30 wiper motor linkages
Can these parts be dissembled apart from the motor. Mine looks twisted and the wiper motor is still good; just wondering if it can be replaced instead of buying a motor with it.
be30318i is offline   Reply With Quote
Old 07-07-2010, 05:08 PM   #2
Ceeker
yes it can. 3 bolts hold the motor to the frame and 1 holds it to the regulating arm. I just removed one from my car. :-)
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 07-07-2010, 09:37 PM   #3
be30318i
well mine all i can see is that there is the linkage and the connector ball thingy that around it. Well obviously I got this problem because the linkage doesn't hold the ball thingy everytime I use the wipers; ball thingy comes off the linkage. Then I have to use two screw drivers to put it back in and if I lucky the linkage doesnt come off the ball thingy "BUT IT DOES EVERYTIME" LOLZ
Old 07-07-2010, 10:28 PM   #4
Ceeker
replied to your pm.
Old 03-10-2011, 08:52 AM   #5
Ceeker
You can't get the motor out of the vent hole..ain't gonna happen. You have to remove the metal shield in behind the rocker cover/engine against the fire wall first. Then you have to take the blower motor assembly out. ONLY then you might have small enough hands to get to the 3 bolts holding the motor on the linkage to get the motor out through the blower motor access. I have never tried what you are trying but then again, what the heck! To make the job easier I would pop one of the arms off the linkage and then you can wiggle the assbly out after you remove the wipers/arms and the hold down nuts at the wiper arm pins.
I've pulled about 3 of these and it has been this way every time.
Btw, your motor is most likely toast. if it is doing that. But you'll be able test it once out.
