Old 06-29-2010, 06:48 PM   #1
Flipr78
How to change my Fuel Injectors - M20
I am new to all this, never owned a German Vehicle before, not that there is that much difference, but can someone show me a good Step by step with pictures of how to swap out the Fuel injectors in a 1987 BMW 325i Convertible?
I have seen a few DIY articles but none with pictures. If anyone could point me in the right direction it would be much appreciated.
Flipr78 is offline   Reply With Quote
Old 06-30-2010, 10:20 AM   #2
I've never seen a write up with pic, maybe there's some in the Bentley.
http://www.maxbimmer.com/forums/showthread.php?t=130524
Old 06-30-2010, 12:28 PM   #3
I should have made a diy when I changed mine last year.
It's not too difficult though, if you read the write ups out there and look at your car you'll be able to figure it out. Just make sure when you pull the line off the fuel rail you have a rag covering it because if you don't gas will spray everywhere. The only thing that might not be detailed in the write ups is that in order to remove the injector wiring harness, the main connector is held in the bracket by a plastic threaded ring, you have to unscrew that then you can pull the harness out.
Old 06-30-2010, 12:59 PM   #4
Flipr78
thanks for the tips, I am going to tackle it today.
