Welcome to!
Old 06-25-2010, 10:20 PM   #1
poolays's Avatar
water pump problem
anybody experienced the waterpump impeller seperating from the pump unit and disappearing into the engine somewhere? i just bought a 1992 325is and was overheating, i replaced the water pump and couldnt find the impeller in the water pump cavity or passage.
although it is running ok now and coolant is circulating could this cause any damage?
poolays is offline   Reply With Quote
Old 06-25-2010, 10:23 PM   #2
because they are plastic most likely it became so brittle that it disintegrated. not much you can do in any case if it didn't. They are common for breaking. Find yourself one with a metal impeller.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 06-25-2010, 10:28 PM   #3
poolays's Avatar
sounds good, hopefully ill be ok
