Old 06-24-2010, 04:37 PM   #1
El Gato Liso
El Gato Liso's Avatar
wont turn over...
i wired up the m50, and when i turn the ignition, the crank spins almost 1/4 circle then all i hear it tick tick tick tick tick tick tick....*smoke from the wires*
when i turn the crank in the front by hand, the starter gives it a good 1/4 spin.
any ideas?
R.I.P. E30
El Gato Liso is online now   Reply With Quote
Old 06-24-2010, 04:48 PM   #2
slimjim
Almost Sideways
ur starter took a shit?
Old 06-24-2010, 11:14 PM   #3
matty.dc
matty.dc's Avatar
that sounds like there isn't enough juice going to the starter if the solenoid just clicks after a 1/4 turn.
2013 Ford Edge - Daily Driver
Old 06-24-2010, 11:42 PM   #4
Smoke indicates loose conection most of the time...
Old 06-25-2010, 01:06 AM   #5
Smoke from the wires? Did you look for any burn / bare wires or connections?
Old 06-25-2010, 07:05 AM   #6
e30_kid89
The Afro-stig
e30_kid89's Avatar
Did you put the FW back on??and try?
Old 06-25-2010, 10:36 AM   #7
El Gato Liso
all the connections are tight.
the fw is back on and the engine can rotate by hand.
hehe i think its a sign saying stop while you're ahead and put the m20 back in.
R.I.P. E30
Old 06-25-2010, 11:41 AM   #8
BigD
the misanthropist
BigD's Avatar
Do your starter and flywheel match? (ie M20 flywheel/M20 starter, M50 flywheel/M50 starter)
Old 06-25-2010, 01:52 PM   #9
HavocSteve
Just wondering if timing is an issue? also the distributor. Don't know much about the m50 but maybe it might spark something you didn't think of.
Old 06-25-2010, 02:29 PM   #10
El Gato Liso
fw and starter (both off m20) do match, battery is fully charge.
and i highly doubt timing being an issue.
R.I.P. E30
Old 06-25-2010, 02:48 PM   #11
Give the starter a few taps with the hammer.
Are you sure you wired it up right?
The clicking starter usually means not enough juice of a start is gone.
Old 06-25-2010, 10:01 PM   #12
El Gato Liso
UPDATE.
problem solved. engine runs....
PROBLEM: start stopped and ticked the night away. 1 ground wire in harness fried.
SOLUTION: apparently only 1 engine block ground isn't enough. so i wired up another on the starter side....and murder she wrote.
R.I.P. E30
Old 06-25-2010, 11:01 PM   #13
HavocSteve
Good to hear. I love flooring my M20 when I'm just fooling around Oshawa. I bet that M50 would just rocket. Have you taken it for a little spin around the block as of yet?
Old 06-25-2010, 11:49 PM   #14
El Gato Liso
the M20(b25) is a beautiful engine. i have no idea what driving the m50 is like! i still need to do the brakes, clutch, and engine cooling!!!
R.I.P. E30
