Old 06-23-2010, 06:23 PM   #1
blastedM3
Jane & Finch
blastedM3's Avatar
E36 M3 aux fan is not working... Help
I need some help with this damn thing. It's starting to piss me off
the fan is not turning on at all. I replaced the fuse and both relays. At the end of the terminal where the fan connects there Is mo power. But there is power is the relay.
Is there any way to find out what exactly the problem is.
Could the temp switch be burnt out?
Any help is appreciated.
1997 E36 M3-Sold
1991 318ci-Project Car-Almost Done
93 Honda HB-Daily Beater
blastedM3 is offline   Reply With Quote
Old 06-23-2010, 07:56 PM   #2
doogee
doogee's Avatar
Unplug the temp switch and stick wire into the ground port and the other end in the high speed or low speed hole. It's really easy. If the fan works on both speeds, then it's the switch.
Dakar M3 Track Build Thread
Old 06-23-2010, 09:35 PM   #3
BmW1819
does your ac work pressure are good??
Old 06-23-2010, 10:28 PM   #4
blastedM3
Jane & Finch
blastedM3's Avatar
Ac does not work.
The fan works. I'm 110% sure of that. I think it is the switch cause I plugged it out and put one wire into the ground and the other on the low and high speed but fan didn't power up.
1997 E36 M3-Sold
