Old 06-22-2010, 04:29 PM   #1
aa34s
hitting noise from the back
anyone know that what will cause the swaybar link hit the drive shaft??
will it be a bad shock?? Or something else??
aa34s is offline   Reply With Quote
Old 06-22-2010, 07:53 PM   #2
Assuming your link is actually bolted to the trailing arm and the sway bar I don't think the geometry will allow the swaybar link to hit the CV shaft. If you were to massively bottom out the sway bar MIGHT rub the CV shaft... but at that point other things have probably already broken
Just to clarify what you're talking about...
Old 06-22-2010, 08:43 PM   #3
Maybe you meant half-shaft instead of driveshaft?
Old 06-22-2010, 09:07 PM   #4
aa34s
yes, i mean the half-shaft
the linkage that connect the sway bar and trailing arm touch the half-shaft
Old 06-22-2010, 09:22 PM   #5
Your sway bar could be installed incorrectly maybe?
Could be a torn mount?
Could be a number of things...
Take a few pics and post them if you can. That'll help us diagnose your problem.
Old 06-22-2010, 10:56 PM   #6
Aloush
when do u usually hear the knocking noise? wonder if its same as mine.
I usually hear it when iam in gear then hit the clutch is when i hear a bang in the back, not sure what that is..
Aloush is offline   Reply With Quote
Old 06-22-2010, 10:59 PM   #7
HavocSteve
Does it do it when your in like 3rd gear coming to a roll so you don't have to up-shift so much? I did that once and my car knocked from the back but I believe is was the Diff just knocking about. I know I need to change my CV joints =\
Old 06-24-2010, 01:05 PM   #8
aa34s
It hits when I drive on a bumpy road and i can see that there's a scratches on the half shaft for both sides
Old 06-24-2010, 01:12 PM   #9
talltorontoguy
Go Topless
talltorontoguy's Avatar
Upper shock mounts could be a cause of knocking on bumpy roads, although that wouldn't cause scratching of the 1/2 shaft. Exhaust also runs under 1/2 shaft, is it loose?
Join BMW Club of Canada! Click HERE
Best Engine, Bimmercruise '10 / 2nd - e30 Wild, Bimmercruise '10 / 1st - Best Cabrio, Trillium @ Tedfest '11 / 1st - e30 Wild, Bimmercruise '11 / 1st - e30 Wild, Bimmercruise '12 www.vertnation.com
talltorontoguy is offline   Reply With Quote
Old 06-24-2010, 04:51 PM   #10
slimjim
Almost Sideways
^+1 on the shock mounts
