Old 06-17-2010, 08:59 PM   #16
richie_s999
Get the ones from Trev!!!
Old 06-17-2010, 10:11 PM   #17
HavocSteve
Yea, if you guys think it's best then I should pop by and grab it off him tomorrow then at the meet. Can I get a thermostat from Crappy Tire? I think this one is about to go on the frits because I was getting pretty close to red when I finally got to Timmies. The cooling fan spins and the coolant is topped up. So I can only think of the thermostat being the problem. Even then, my batteries in my cluster are going so my ECO for gas and my RPM gauge don't work (that's next weeks fix). So maybe that might be throwing the reading off? Just looking for possible hints. I'm getting the last rad hose that I need tomorrow and hopefully getting a rad later on next week (since mine is just starting to leak coolant but it's not really a leak tbh). Just want to get all this shit fixed >_<
Old 06-17-2010, 10:33 PM   #18
richie_s999
Check the v belt on the waterpump to make sure it's tight, thermostat should fail in the open, if the belts tight check the clutch fan, start the motor and stick a rolled up newspaper in it, if it stops easily it's ****ed.
If the temp gauge is jumping around it's electrical, steady rise is cooling system
If only one side of your cluster is out smack the dash above it, usually a worn out conection, you'll see lots of e30's driving around with people smacking the dash.
Old 06-17-2010, 10:50 PM   #19
20w50 is the good stuff to run in your M20 during the summer. The rest gets burned up so fast you don';t even know.
Old 06-18-2010, 12:22 AM   #20
HavocSteve
Yea, I picked up Castrol GTX n/s 20w-50 like you guys mentioned. Might be gay during the winter for starting but w/e, I can let it warm up.
Richie, I figured it out in the dark lol. My coolant hose running from the reservoir to the thermostat, the hose has a break at the clamp, so I'm guessing the hose got old just like the other one I replaced. Grabbing it off my buddies donor car for 10$ and I'm thinking I might as well get a new thermostat also. Also my rad where the plastic sides meet, it's barely leaking as well. So I'm going to switch the hose over to the newer used one that's perfectly fine and get some of that rad leak stop crap that I just heard about which should stop the rad leak itself where the plastic sides meet. When I opened the reservoir, it was empty poor girl ran pretty dry so I put some more coolant in it for now. I figure since it sat so long without moving, the hoses probably went for a shit. Also since I'm a new stick driver the first day I was gunning it down all the gears ahhaha.. so now everything is broken in or broken, but it's the only two last things that need fixing, besides body work (that's for another day). Hoping to have it fixed and test run'd before the meet tomorrow. I really want to bring my car out so you guys can see my POS E30 ahaha..
Anyways, thanks for the tips. I've learned more then my whole life time in 3 weeks with this forum about cars. Tomorrow is going to be a shit day since it's first oil change and coolant leak fixing day >_< oh man...
Old 06-18-2010, 12:47 AM   #21
You should run 10w40 in winter. 20w50 is too thick.
craz azn is online now   Reply With Quote
Old 06-18-2010, 12:49 AM   #22
HavocSteve
Ok, thanks Rudy. PM is inbound btw. I was thinking 20w-50 would be like glue during winter.
Old 06-18-2010, 01:11 AM   #23
El Gato Liso
El Gato Liso's Avatar
from from august 2008 to june 2010, my M20 engine has only had 2 oil changes. and i drove a LOT (to and from bronx, NY) and so much pointless driving on heavy gassing.
and i ran 20w50 castrol. its the perfect summer oil for e30 m20!!!
R.I.P. E30
El Gato Liso is online now   Reply With Quote
Old 06-18-2010, 01:20 AM   #24
HavocSteve
Rofl! That ain't right >_< at least we know the engines are tough as nails.
Old 06-18-2010, 01:50 AM   #25
If you cant find a way to do an oil change, you aint ready for an E30. Simple as that!
Old 06-18-2010, 04:52 AM   #26
+1 on 10w40 during the winter, thats what i ran.
Also I recommend you get a proper thermostat, i've always had problems with the crappy tire ones.
Get a Wahler one from Autopartsway.ca ~$40, shipping is free if you order over $75.
Also the cause of your car running hot could be a weak fan clutch, take a roll of newspaper and try to stop the fan while running. If you can stop it easily you have a bad fan clutch.
Old 06-18-2010, 09:32 AM   #27
e30_kid89
The Afro-stig
e30_kid89's Avatar
Originally Posted by E30M42cab View Post
It should be noted that M20's don't need oil changes, they just burn the oil off, and you just add some more. New oil every 2500kms. All you have to do is change the filter every 100,000kms!!
QFT...The 2 m20 powered e30s were both this way. One burned it and the other slowly leaks it. Must be setup this way from the factory!
Old 06-18-2010, 10:24 AM   #28
HavocSteve
The thermostat is fine, I just want to replace it just to be on the safe side of things. I did the newspaper trick and it works fine so good news there. Getting the rad hose off my buddy later today so that should solve my problem asap along with putting that aint-freeze stop leak stuff into the rad itself since the metal meets plastic seems to have a wet look to it.
I was afraid of the head gasket going and leaking into the oil (I think that's what happens). But when I checked the dip stick, there wasn't anything funny with the oil on the stick, and actually the motor oil looked nice and clean (who knows if it had a oil change done somewhat recently from the previous owner).
Old 06-18-2010, 12:33 PM   #29
dble Trouble
TAKE IT TO THE TRACK
dble Trouble's Avatar
I'm surprised no one has mentioned MGM (Marcus Glarner Motors) here. He's in Port Perry right above Oshawa. I get 90% + of my parts from him and if there's something that needs to be done above my skill level the car goes to him. He's an avid BMW fan as that's pretty much all he works on except for the odd Ferrari!!!! Just my two cents again.
Old 06-18-2010, 12:44 PM   #30
I'm pretty sure he'd laugh in your face if you went there expecting a quick lube type service.......lol
Unless things have changed and he's really slow.
Thats not the type of business he is looking for, and rightfully so.
