Old 06-09-2010, 06:49 PM   #1
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
Send a message via MSN to AlpWhitE46
Code 104
So as some of you read I had the mechanic put in the new vanos and seals + new oil was changed right after.
After second start i got CODE 104 - VANOS exhaust camshaft, end position reached.
This is one of the codes i was getting before, I guess the other one dissapeared..
Does anyone know what this could be now?
The car kinda starts a bit off, and does not idle fully properly...
I HATE VANOS.
AlpWhitE46 is offline   Reply With Quote
Old 06-09-2010, 07:00 PM   #2
mirek
mirek's Avatar
Code P0104 is MAF according to my book,
Old 06-09-2010, 10:23 PM   #3
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
What book is that?
Sorry I'm just trying to figure out what the hell else is wrong... What i wrote is what the mechanics computer checked out
I just started it up again and it was studdering the iddle...
Old 06-09-2010, 11:55 PM   #4
uzi577
RUNING BOOST
uzi577's Avatar
I think he refers to Bentley manual. I briefly checked the P0101 is MAF(mass air flow). BMW code 8. It is close but I could not locate the P0104.
All the VANOS codes start at P15xx.
good luck
uzi577 is offline   Reply With Quote
Old 06-09-2010, 11:59 PM   #5
EuroSpec_92
MPOWER
EuroSpec_92's Avatar
ill check it out for you in the morning, i have a better program at teh shop
99 Estoril M3
EuroSpec_92 is offline   Reply With Quote
Old 06-10-2010, 01:18 AM   #6
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
Thanks Euro!
Can't wait to resolve this issue already!
Old 06-10-2010, 01:52 PM   #7
mirek
mirek's Avatar
OBDII codes, assuming you used an obd2 scanner,
http://www.obd-codes.com/p0104
Old 06-10-2010, 04:18 PM   #8
MarkD
MarkD's Avatar
What program do you have ? A GT-1 is the best tool to use.
Old 06-10-2010, 04:25 PM   #9
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
I'm not sure what my mechanic used - all i have is a printed receipt that says X431 DIAG report.
Old 06-10-2010, 07:26 PM   #10
MarkD
MarkD's Avatar
That is the Launch diagnostic tool. http://www.x431.com/ Not as good as a GT-1.
Old 06-10-2010, 11:45 PM   #11
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
So what does this mean?
Could it be the MAF?
I was just parking and as I parked it was studdering, and then turned off..
luckily I was able to turn it on
Old 06-11-2010, 05:25 AM   #12
MarkD
MarkD's Avatar
What does your mechanic say? If he does not know, you should take it to someone who has a GT-1. RMP has one. I also do, but don't have time to do any scans till next week.
Old 06-11-2010, 10:10 AM   #13
EuroSpec_92
MPOWER
The code shows as a bmw-FC code.
There is no P0104.
So if it is the FC code it is Camshaft position timing over advanced. Or system performance bank 1.
Picture attached.
99 Estoril M3
Old 06-11-2010, 04:58 PM   #14
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
last time i turned it on ran perfectly fine...
Here is the second last time i turned it on..
Should the car do this btw when i rev it and release the gas, its like it has a little point where it stops then drops a bit.. then you can hear it studdering..
http://i.imagehost.org/download/0154...-20100611-1418
Old 06-12-2010, 11:06 AM   #15
uzi577
RUNING BOOST
uzi577's Avatar
Start with a basics
Take the MAF sensor off clean with a carb cleaner.
Or if can get your hands on working MAF sensor plug it in see if it will solve you problem.
BMW is very picky on the reading it gets for the MAF. The range of problems can be cause by it is huge.
Please re-read the codes. It will help you determine further action.
