Old 06-10-2010, 03:28 PM   #1
bmwconnect
BMW Tuner
bmwconnect's Avatar
Etest Results
sharing etest results 1995 Turbo 318i, 38Lb injectors, 91octane, Motronic Tuned by bmwconnections, 2.5'' $40 ebay catt with crank vent hooked up, fresh oil ,and car idled ten mins before test . According to the shop I went to this is one of the best tests they have seen involving a bmw
There is no reason for other turbo conversions to fail if they are tuned correctly
Old 06-10-2010, 04:28 PM   #2
carjoe
carjoe's Avatar
Awesome. Good for you!!
93 325is - sold!
2000 540ia- sold!
Old 06-14-2010, 04:43 PM   #3
gervs
gervs's Avatar
hah, nice. I couldn't even get my perfectly running e36 325 to pass.
gervs is offline   Reply With Quote
Old 06-14-2010, 05:07 PM   #4
bmwconnect
BMW Tuner
bmwconnect's Avatar
just for the hell of it I would love to see how it does without a catt installed
Old 06-14-2010, 08:20 PM   #5
proudbmwownr
why is the NO PPM raw N\A? they didnt test it ?
proudbmwownr is offline   Reply With Quote
Old 06-14-2010, 08:31 PM   #6
Duct_Taper
Sticky
Duct_Taper's Avatar
2-speed idle test doesn't check NO.
Duct_Taper is offline   Reply With Quote
Old 06-14-2010, 09:39 PM   #7
Great Job Bear... What's the trick to getting them to do the 2 speed idle? When you lower CO, NOx goes up. Given that your CO was 0, the NOx was probably very high, but not tested with idle test.
Typically, etest is striking a balance between rich (high HC and CO) and lean (high NOx).
Anyway, I'm very impressed Bear, and you know I don't impress easily.
Old 06-14-2010, 09:43 PM   #8
most engines produce very little emissions under zero load.
just tell them the car is too low and was damaged last time it was on the dyno.
Old 06-14-2010, 09:53 PM   #9
proudbmwownr
i wanna know as well... my car passes everything with flying colors except Nox.
Old 06-14-2010, 11:02 PM   #10
bmwconnect
BMW Tuner
bmwconnect's Avatar
Jay and proudbmwownr its the trick that propr'one has suggested. My car is too low to run on the one at the shop anyway. I would have passed a rolling road test also no doubt there . it helps when the afrs are bang on
Old 06-20-2010, 10:54 AM   #11
radi0activem
Just got mine tested this morning. Warmed up the CATS for about 10 mins of driving and idle for about 10 waiting for DriveClean to open.
IDLE
HC ppm limit 15o Reading 1
CO% Limit 0.70 Reading 0.00
1282rpm
HC ppm limit 60 Reading 1
CO% Limit 0.33 Reading 0.00
NO ppm Limit 450 Reading 0
Brian
2003 530i
radi0activem is offline   Reply With Quote
Old 06-20-2010, 12:48 PM   #12
bmwconnect
BMW Tuner
bmwconnect's Avatar
IDLE
1282rpm
Post your sheet!
Old 06-20-2010, 06:30 PM   #13
radi0activem
Here you go!
I have to say, the car did not like doing the etest. He turned the ASC off but it didn't like not moving with the rear wheels going 40km/h ! The guy said the all the lights(ABS, ASC, etc) will go off eventually, but I didn't take any chances. I plugged in the laptop and cleared the codes with Carsoft.
Brian
2003 530i
Old 06-20-2010, 07:42 PM   #14
bmwconnect
BMW Tuner
bmwconnect's Avatar
Your dilution is amazing!! 02sensors are working very very well nice pass!
Old 06-21-2010, 07:53 AM   #15
radi0activem
I'm glad they are working well. I wasn't really looking forward to changing them. But now I guess I won't need to anytime soon (crossing fingers).
Brian
2003 530i
