Old 06-10-2010, 12:41 PM   #1
windsor318is
Nitrous Junkie!
windsor318is's Avatar
ABS + ASC warning lights??
recently ive had the abs and asc(traction) warning lights come on every time i start my 328is. i use to be able to turn the car off and on, and it would clear them but now they are on permanently. anyone ever have this happen on there e36? someone i work with had this same problem on there 2006 vette and it was a brake module of some sort, just wondering if we have a module that may have gone bad as well
thanks al
Old 06-10-2010, 12:49 PM   #2
Does it trigger a code? Get a code reader and read the code it usually tells you what has failed. My bet would be on a wheel sensor as those are more common items to fail.
Old 06-10-2010, 01:04 PM   #3
Its a problem with ABS. Probably a speed sensor. When ABS fails, asc+t fails too. Fix the ABS and the traction control will work.
Old 06-10-2010, 01:08 PM   #4
328IScreamer
328IScreamer's Avatar
it's def the wheel speed sensor
I've experianced this before
Old 06-10-2010, 02:40 PM   #5
windsor318is
Nitrous Junkie!
ahhhhh that makes sense, i know i have a bad one in the front from when i changed the wheel bearings last summer, ill have to buy another bearing and replace the sensor this time, thanks for the quick info guys!
Old 06-10-2010, 11:54 PM   #6
taxi615
yeah my M3 does the same but only when its colder outside...I will have to check which sensor is making the ABS fail sometimes. I have one in front and one in the rear right???
taxi615 is offline   Reply With Quote
Old 06-11-2010, 12:44 AM   #7
blk325i
blk325i's Avatar
four total, one at each wheel
blk325i is offline   Reply With Quote
Old 03-23-2011, 05:14 PM   #8
windsor318is
Nitrous Junkie!
anyone have a diy on the abs sensor removal, really dumb design, anyone have anyluck removing one ever. over time it becomes a press fit from corrosion. any tricks would help!
