Old 06-07-2010, 08:10 PM   #1
non-ix vs. ix rear brake caliper
So I checked realOEM and it says that the rear left brake caliper for a 325i is the same as a 325ix. Since realOEM isn't always 100% I just wanted to see if anyone knows if this is true from experience.
The reason I ask is because my caliper is seized and Filip has an ix caliper I can buy if it'll work.
Thanks in advance.
Old 06-07-2010, 10:38 PM   #2
supernaught
supernaught's Avatar
i thought they were different but I can take measurements from one I have in the garage if you want to compare to yours
Old 06-07-2010, 10:48 PM   #3
Lol measurment wont help! From what i remember the difference was minimal...and only obvious when you have the two side by side! But what i cant remember is if it applys for the front only, or ther rear too...
Sorry, its been years since i did it, and my memory isnt what it used to be! lol
If i get a minute, i will remove both and compare...
Old 06-07-2010, 10:54 PM   #4
supernaught
it might be the same come to think of it... the trailing arm is the same, the rear hub is different(wider) and the rear disc hat is deeper, the hat and hub might cancel each other out just fine.
Old 06-08-2010, 06:56 PM   #5
Thanks for the hook up Fil
