Old 06-10-2010, 09:08 AM   #1
ryanjv
ryanjv's Avatar
Send a message via MSN to ryanjv
Stock Radio Code Procedure. UPDATE: Now fix the antenna
ola,
the car is a 1987 325e. when i turn the car on then turn the radio on it says CODE. I got the proper code from the dealer (it wasn't the original so i pulled it out and got the serial number, so don't worry thats been checked a few times).
So anyways, i get prompted for 'CODE' and enter it. upon entering the fifth number it just beeps and stays at code. Is there a method to properly entering the code? at first i thought it was like my brothers acura where when you exceed the maximum tries it locks out and you have to disconnect the battery to try again. Talked to a couple dealerships (thanks Maranello Mike for getting me the code) and they weren't 100% sure but they said that if i leave the car on for an hour it should let me enter the code and work.
anyone have any ideas? or does anyone know the proper procedure for getting this stereo to work?
ryanjv is offline   Reply With Quote
Old 06-10-2010, 11:43 AM   #2
ryanjv
ryanjv's Avatar
so waiting an hour worked. entered the code and yay i have radio.
now i hear the antenna trying to lift, you hear it whirring, but it won't go up.
I've lubed it up and manually pulled it up while the car is off. It was sticky and seized, so i cleaned off teh antenna and worked it up and down to make sure it won't get stuck.
But now when i turn the radio on and off, the antenna only goes part way up or down, sometimes. Am i going to have to pull out the little antenna casing and poke around inside? or is there something else i need to do. it sounds like its just not catching something and going. anyoen know what its like inside and the mechanics of how it works?
Old 06-10-2010, 11:48 AM   #3
HavocSteve
Why not unscrew the antenna and just buy a aftermarket small plastic one, they are better anyways. Get more signal.
