Old 06-03-2010, 01:24 PM   #1
audi5000
audi5000's Avatar
Where do these go??
so i decided to swap the cam in last night.
in and out no problem.
torqued the head down and decided to call it a night.
that was probably a bad idea because when i woke up to finish making connections i was left with 3 hoses.
must have forgot it overnight or something?
anyways i searched all this afternoon.
checked and double checked the maunal.
couldnt find where they go!
so now i need your help
i believe 2 are vacuum and 1 is coolant
ill do my best to show you what im talking about.
if im leaving something out just ask.
an obvious one is coming off the valve cover.
another from the throttle body
and then this coolant coming from under, along the block.
audi5000 is offline   Reply With Quote
Old 06-03-2010, 01:33 PM   #2
audi5000
audi5000's Avatar
keep in mind that this is not the original engine, so it has been played with.
also i looked into those 2 vacuum hoses and the one from the TB actually comes all the way around into the one from the VC. could that be?
Old 06-03-2010, 02:22 PM   #3
Ceeker
one I know goes into the throttle body - the small narrow one for cooling. its hard to tell from the pics what you have going on there. I'd have to see it in person.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 06-03-2010, 03:34 PM   #4
audi5000
audi5000's Avatar
hmm i think i already have one going to the TB. ill double check!
Old 06-03-2010, 03:43 PM   #5
dmytro
dmytro's Avatar
haha I like the broken oil dip stick I had similar thing, that disconnected bend hose in pic#3 or (#4 shows it better) goes into the "Throttle Body" cooling, (there is 2 of them), I see from pic you got other already connected, so connect the second one.
Edit: If you have a leaky gasket there, you can just connect those hoses together without running them to "throttle body". ...that cooling is kinda useless.
dmytro is offline   Reply With Quote
Old 06-03-2010, 05:43 PM   #6
audi5000
audi5000's Avatar
okay i found the one on the TB and started her up!!!!
thanks for the help!
now my only is when at an idle i give it gas, she tries to stall out or lag.
fuel maybe? ???
Old 06-03-2010, 11:07 PM   #7
supernaught
supernaught's Avatar
vacuum leak maybe, a hose that isnt connected in the right place, or cracked boot, etc...
Are all your electrical connectors in the right spots?
Old 06-04-2010, 10:40 AM   #8
dmytro
dmytro's Avatar
From pics your Idle Control looks like it may be bad...whats that green electric tape? also it suppose to be positioned "HORIZONTALLY" not vertically and that hose made from electric tape thats just bad . definitely not a German engineering
Old 06-04-2010, 10:49 AM   #9
audi5000
audi5000's Avatar
thats how it was when i purchased the car.
i have not had a chance to replace it yet.
but now i guess i should really do something about that
Thanks.
Old 06-04-2010, 10:50 AM   #10
audi5000
audi5000's Avatar
Oh and the tape was for marking it.
Old 06-04-2010, 12:59 PM   #11
cirrusblau
As far as I know, orientation of the idle control valve doesn't matter.
Is this delay in response to aggressively revving the engine, or gradually getting on the throttle? A stumble then rev indicates A/F mix out of whack - can't remember what indicates lean and what indicates rich. Could be other things too.
Check that you don't have vac leaks - intake boots, vac hoses, oil dipstick seal, oil filler seal, etc. Also, check that you've got the FPR vac line attached and no fuel is the vac line. Also, check that the spark plug wire sensor is properly attached (it's a hall sensor on one of the wires - wire 1?).
If problems persist, check that the various sensors on the engine are within spec.
Old 06-04-2010, 02:17 PM   #12
supernaught
sure looks like your crank case tube isnt seated, did you fix that already?
Old 06-04-2010, 02:32 PM   #13
dmytro
dmytro's Avatar
Oh yeah I didn't even notice....the crankcase! Hose is definitely not original (ask me how I know) it goes under the manifold, on top of fuel rail and into the crankcase and its very tight in there.
Old 06-04-2010, 03:14 PM   #14
supernaught
wtf? under manifold, over fuel into crankcase? what hose?
The crankcase vent tube goes from the crankcase to the bottom of the intake manifold, the OP's isnt seated properly in the one pic.
the TB has hoses coming off the left side(when standing on diver side of the bay) 2 cooling hoses that just flow coolant around the vac line that connects in the middle and run from the rear of the engine through the TB to the thermostat housing.
that vac line runs from the TB to the valve cover vent.
2 vac lines come off the right side of the TB to the booster
and one from the bottom of the TB to the vapour cannister/collector.
One from the boot into the hose to the booster
one from the boot to the ICV then to the TB.
Airbox to AFM to boot.
A loose connection at any of these points or a bad gasket(intake mani gskt, TB gskt, valve cover gskt) will be a vaccum leak.
Theres a good question above though, does it bog down when you apply throttle or does it surge then bog down?
Old 06-05-2010, 06:51 PM   #15
dmytro
dmytro's Avatar
This is the one I was talking about part# 11 15 1 708 801
