Old 06-03-2010, 12:55 PM   #1
dejan_da_dude
E36-err
dejan_da_dude's Avatar
Failing emmitions - Please Help
Hey everyone, I have had my e36 318 with an e36 m3 engine conversion for about a year now and its time to do the emission test. Now the m3 engine has been converted to OBD1 and the airpump on the left hand side of the engine bay has been taken off, from what I read this is just to suck in cold air into the engine on start up..
I just replaced the o2 sensor and new cat. My issue is that my NOx levels are going crazy high. I used my friends stock exhaust and my NOx level on his was 2591 and the limit is 485. My exhaust is a 2 1/2" pipe with a new Cat, Supersprint muffler and the OBD1 system only uses 1 O2 sensor.. any advice?
Here is my most recent Etest.
dejan_da_dude is offline   Reply With Quote
Old 06-03-2010, 10:28 PM   #2
325isdan
I am sorry I can not help, but they test your inline 6 as a inline 4?
325isdan is offline   Reply With Quote
Old 06-03-2010, 10:41 PM   #3
simplycars
simplycars's Avatar
the car is still technically 318i - swap is not documented at the mto and vin doesn't indicate the swap hence it is 4 cylinder.
simplycars is offline   Reply With Quote
Old 06-03-2010, 10:49 PM   #4
325isdan
but wouldn't the tolerances for an inline 6 be greater than an inline 4?
Old 06-03-2010, 11:29 PM   #5
blk3
blk3's Avatar
he would still fail even if it was tested as a 6, check out the nox reading
Old 06-04-2010, 09:50 AM   #6
richie_s999
you should be able to get tested under the "hot rod" test.
your car being a 93, the motor you have in it was not avalible in that model year so you may be able to have them test it under that rule.
that being said your HC is way high, spend the money on a drive clean diaognostic, not only can it pin point why your failing, but your motor is not running propperly and could actually improve performance and gas milage if you get it fixed
Old 06-04-2010, 11:20 AM   #7
Does the s52 have an EGR valve?
If so make sure that is functioning correctly.
Old 06-04-2010, 03:01 PM   #8
dejan_da_dude
E36-err
that being said your HC is way high, spend the money on a drive clean diaognostic, not only can it pin point why your failing, but your motor is not running properly and could actually improve performance and gas mileage if you get it fixed
Your absolutely right about the hot rod since its a 92/93 production date. Thank you so much richie_s999. I will definitely get that taken looked at. I used my friends exhaust and I passed the HC level perfectly. Its most likely because I'm using a mangaflow cat...
and for "Does the s52 have an EGR valve?" question, I had my car converted onto the ODB1 system, so it might have been taken of, I assume you might be talking about the pump that's attached to the valve on the left side of the engine(exhaust manifold)
Old 06-04-2010, 03:02 PM   #9
dejan_da_dude
E36-err
Yeah i asked the etest guy since he's a friend of my dads and he said the limit levels are the same.. which I have no idea now since wouldnt the 6 cyl. product more gases
Old 06-04-2010, 03:32 PM   #10
Not having an EGR (exhaust gas recirculation) valve can be the cause of the high HC and NO readings, so if your car had one, and then it was removed that could potentially be the cause
Old 06-04-2010, 03:43 PM   #11
No not really, i'm not sure but i believe removing the secondary air pump effect emissions, but i thought that was only on start up. It sounds like it's a bigger problem most likely due to the swap. Is the motor running strong? Are you getting good gas mileage?
Old 06-04-2010, 05:05 PM   #12
Petinko
legally the mto can only make you spend 450$ in emissions related repairs... it doesn't need to pass.
http://www.ene.gov.on.ca/en/air/driv...v_faq.php#What is the Repair Cost Limit and what repairs and services qualify?
Petinko is offline   Reply With Quote
Old 06-04-2010, 06:04 PM   #13
richie_s999
You can only do that once. In 2 years it will have to pass or no sticker.
Old 06-04-2010, 06:17 PM   #14
dejan_da_dude
E36-err
Exacly, Ive been looking into the hot rod certification because it should work.. The engine was not made in the year that my car was manufactored...
Old 06-04-2010, 06:19 PM   #15
dejan_da_dude
E36-err
The engine runs amazing, I just put in a new OBD1 tune chip and a newer O2 sensor. Pulls really good and gas milage seems good too.
