Old 03-29-2003, 04:28 PM   #1
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
Send a message via MSN to AlpWhitE46
Network/Internet
Ok, my network and my internet was working fine all the time since i moved in, and a couple of days ago when i came home from school (i have 2 computers, one which is my brothers that is connected to rogers, and networks to mine) my internet was down on my computer. I went downstairs to check if my brothers computer was on, and it was..so i went to network properties and tried to repair, but nothing happened, I restarted and shut down the computer, and also restarted my brothers and nothing happened.. I still had no internet and could not see my brother through network..
I brought the computer downstairs and tried switching the network cable, nothing again...(i use 2 network cards for my brothers computer, and one on mine)
What else could the problem be? I can only think of changing the slots, or changing the network card?
Help please
AlpWhitE46 is offline   Reply With Quote
Old 03-29-2003, 04:47 PM   #2
MP328
Krv Svoju Za Bosnu Moju
MP328's Avatar
Send a message via MSN to MP328
u might wanna post on these board for more help
http://www.thecomputermechanics.com/forums/index.php?s=
http://cgi.techtv.com/messageboards?...ew&board_id=17
MP328 is offline   Reply With Quote
Old 03-29-2003, 05:45 PM   #3
Miguel
...Delt Smash
Miguel's Avatar
It could be anything!!!
did the plug for your router fall out?
call Rogers at 416-464-3433, tell them you bought a new computer and that they need to reset the connection on their end.
see if that works
Old 03-29-2003, 06:50 PM   #4
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
Im pretty sure its the cable..i thought it wasnt since i switched the cable, but those were straight through and i need a cross over cable...so i will pick it up from my friend and see if it works then...
Miguel, I dont use a router, and rogers wouldnt be able to help since internet works fine, just the network connection the the other computer cannot be detected..thanks
Old 03-29-2003, 08:29 PM   #5
sirex
King Sirex
i say u buy windows xp professional, itll fix everytingand configure everything
Old 03-29-2003, 08:30 PM   #6
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
i have windows xp and had it since it came out...its not it..im pretty sure it would be cable...if not, the network card , otherwise, i dont know
Old 03-30-2003, 12:32 AM   #7
Harry
Whne u are plugge dinto the hub, do the lights on it light up for the port that your system is plugged into?
Harry is offline   Reply With Quote
Old 03-30-2003, 12:40 AM   #8
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
read what i said above, i dont use a router or a hub..
Old 03-30-2003, 12:43 AM   #9
Gamite
Gamite's Avatar
um.. gonna start off with basics, so bare with me, when you connect the wires, does the link light stay up?
essentially your brothers computer is acting like a router since the internet goes to his computer right?
check if both computers are using the same workgroup name.
www.gamite.net
Old 03-30-2003, 02:37 AM   #10
Bill Gates
Bill Gates's Avatar
Send a message via MSN to Bill Gates
ya, start with Gamite's suggestion. looks like your using your brothers system as a gateway (via software).
do an ipconfig (via DOS) on the system that works. then do the same to yours.
both should have the same subnet, and a unique private IP address either 192.168.x.x or 10.10.x.x
make sure both have the same gateway.
then through DOS, ping the main system. if you don't get a reply back, then the problem could be your NIC not being assigned a proper IP.
start with that and let us know.
Bill Gates is offline   Reply With Quote
Old 03-30-2003, 03:06 AM   #11
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
everything is the same guys...i didnt switch anything, its just that one day when i came from school, it just happened to not be working... im 95% sure its the cable..otherwise if not the network card
Old 03-30-2003, 03:09 AM   #12
Bill Gates
Bill Gates's Avatar
if you don't have a hub or router, then you definitely need a crossover cable.
when your inpecting the cable, make sure pins 1, 2, 3, 6 are the ones crossed over.
Old 03-30-2003, 03:15 AM   #13
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
yeah i have a cross over cable..but im guessing it got fuked up..thanks for the help anyways guys.
Old 03-30-2003, 04:08 AM   #14
sonic07
sonic07's Avatar
sounds like perhaps there was power failure and came back up all ip's screw ups ..... from darn rogers but if change computer from one to the next with rogers you have to release the ip from the original computer or else it'll screw up everything untill rogers server rescan ip's. rogers actually record your mac addr. from you nic or router if you have one.
Pedal To The Metal
sonic07 is offline   Reply With Quote
