Old 06-01-2010, 08:11 AM   #1
WUTANGM3
Chip Installation
does any one know of a good website with info on how to do this. i found one on pelican but no pics
WUTANGM3 is offline   Reply With Quote
Old 06-01-2010, 08:53 AM   #2
This is for an E36 but the pics of how to remove the chip are the same for the E30 (figures 7-10)
http://www.pelicanparts.com/bmw/tech...ip_Install.htm
The DME for E30's (at least my car anyways) is located in the glove box. You have to remove the upper plastic pannel to get at it. Also you probably won't have any torx screws that need to be removed (my DME only had tabs that needed to be bent up to remove the cover)
just follow the pelican E30 chip replacement article http://www.pelicanparts.com/bmw/tech...ip_install.htm and use the other link I posted for reference when replacing the chip.
Old 06-01-2010, 10:49 AM   #3
dmytro
dmytro's Avatar
Yeah it is located in your glove box, you need to unscrew 4 (10 or 12mm bolts ) and bend the metal cover clips to open. Depends on the DME (car model) some are made from 2 PCB boards on top of each other....if you have that one you need to separate them in order to access the chip.
Tips:
The main connector may seem to be stuck, you need to unscrew the the DME first and than remove it at an angle.
If you got 2 PCB boards stacked you might want to take time with it. Top board is held tight by clips and only way to separate it is from "main connector" side with screw driver.
dmytro is offline   Reply With Quote
Old 06-01-2010, 10:54 AM   #4
SamE30e
SamE30e's Avatar
One of the ecu's needs to be socketed, I think it might only be for an E though
85 325 - Turbo M52B28.
