Welcome to!
Old 03-29-2003, 07:02 AM   #1
Send a message via ICQ to savemike Send a message via AIM to savemike
Question Will 45 profile tires fit with 18's on my E36?
Hey, I am getting 18's for my E36 325i , and I want to get 45 profile tires, but I don't know if they will fit, or nicely fit for my style car. If anyone knows, leave a reply. Thanks, Mike
savemike is offline   Reply With Quote
Old 03-29-2003, 07:15 AM   #2
Nitrous Junkie!
windsor318is's Avatar
you cant do have to get a 35 series tire so that the overall diameter of your rims are still the same as factory specs.....and 45 will look gay on e36 with 18s
Old 03-29-2003, 01:00 PM   #3
Mr. Euro E30
qimis's Avatar
yea, that'll look a bit too THICK
qimis is offline   Reply With Quote
Old 03-29-2003, 02:31 PM   #4
Most run 225/40/18. Depending on the width of the rim, you may be able to get away with 215/45/18. try to get as close to OEM diameter as possible so as not to create too much error on your speedometer. Check out the FAQ section, there's a tire size calculator there.
Old 03-29-2003, 04:53 PM   #5
Krv Svoju Za Bosnu Moju
MP328's Avatar
Send a message via MSN to MP328
if ur suspension is stock or you have the sport bmw suspension the 45 tires will fit with no problems.
if it is lowered stick with 40 cuz 35 is already a bit too small might bend the rim.
MP328 is offline   Reply With Quote
Old 03-29-2003, 06:10 PM   #6
Ya from my understanding, if you have 18's on an E36 the best size is 225-40-18..............
98323IS is offline   Reply With Quote
Old 03-29-2003, 09:46 PM   #7
4life's Avatar
Dont go with 45 series tires!!! I just went to 225/40/18 from my factory 225/50/16 combo. The overall diameter is already over 1 inch bigger (physically measured, not claculated), which is like getting taller rear end gears, not desireable! So combined with the extra weight and taller tires, my car is a pig!
4life is offline   Reply With Quote
