Old 05-26-2010, 01:19 AM   #1
ganastas
Replacement key/remote
Hello all!!!
It's nice to be here... First time postin.
I've read alot of different post from different
places. But the answers all over the place.
Where's the best/cheapest place to replace or reprogram
a key/remote? I have one from a different car, can it be reprogramed?
It's a 07 335i. I'm also worried who has the missing one? Oh yeah, I'm in the
gta.
Thanks...
ganastas is offline   Reply With Quote
Old 05-26-2010, 09:56 PM   #2
mstearnsy
you have to go to a dealer. A key works for a unique vehicle. If you order a new key from a dealer, bring the key you have, and they can code the car so that just those 2 keys work and the missing key will be useless.
mstearnsy is offline   Reply With Quote
Old 05-27-2010, 09:33 PM   #3
slemmer
Driving in the fast lane
slemmer's Avatar
I just received my key from the US. When the remote didn't work I figured it may need to be programmed. Does any of the Indi's do it as well?
NVM - found the procedure:
Definitions: button 1 on the keys is the one closest to the metal part of
the key (this is the door open button); button 2 is the middle button (the
door close button).
1. Open the car doors using the remote function of your working key.
2. Get in and close (don't lock) all the doors.
3. Put the key in the ignition and switch momentarily to position 1 which is
the first position when you turn the key clockwise. This is the accessory
position. Don't stay in position 1 longer than 5 seconds; then turn the key
back to the off position.
4. Remove the key.
5. On the key transmitter, press and hold button 2. Press and release button
1 three times within 10 seconds while still pressing button 2.
6. release button 2.
7. The system indicates re-programming by locking and immediately unlocking
the door locks.
8. If you want to do more remotes, you must do each within 30 seconds of
step 7 for the preceding key. You just need to repeat steps 5 through 7 for
each key after the first.
You can knock off a dozen keys if you want in a few minutes.
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
Old 05-29-2010, 12:26 PM   #4
ganastas
thanks for all your help. ordering a new one!!! let you know if all works out.
Old 09-06-2010, 08:40 PM   #5
Bimmermann
door close button).
4. Remove the key.
the door locks.
These are definitely instructions on programming an E46 Key FOB. Used E90 keys need to be activated through GT1 or ISTA/P.
Bimmermann is offline   Reply With Quote
