Old 05-18-2010, 05:43 PM   #1
champ0202
Brakes / Suspension
my car = 99 323i with sport pkg with just over 230 000km
As my car has over 230km on the original suspension its time for a change. I am thinking of putting bilstein HD all around with HR sport springs. I am looking to keep the original height. Is there a better setup out there? Or should I go with the sport instead of the heavyduty?
I was looking at zimmerman rotors however I have come across a good deal on Xtreme crossdrilled rotors and hawk pads. Has anyone heard of Xtreme rotors? are they any good? they do come with a zinc coating?
champ0202 is offline   Reply With Quote
Old 05-18-2010, 06:42 PM   #2
nachos23
SweetXi
nachos23's Avatar
A couple of points:
The H&R Springs will drop the suspension 1.5" front and approx 1.2" in rear regardless of the strut/shock used. Bilstein HD would be quite rough; suggest Bilstein Sport vs. HD. But since you don't want to drop height; you can either replace with stock springs and shocks/struts, or go with a coilover kit that allows you to adjust ride height to your preference. You didn't mention budget; which is a conseration, because coilovers aren't cheap.
I prefer the lowered look and feel of my Bilstein SP and H&R SP setup: http://www.turnermotorsport.com/html...D=E46SPORTSUSP
If I wasn't driving an XI, I would have gotten H&R's Cup Kit. http://www.turnermotorsport.com/html...UCT_ID=31019-1
your call.....
My Rides:
2009 335Xi
520HP
H&R coilovers
BBS LM wheels
//M sport package
BMW Personal Audio System
2000 Z3M
Conforti tuned
AFE CAI
++More to come this winter
Old 05-19-2010, 07:10 AM   #3
champ0202
suspension
Thanks for your advice, my car does have a sport suspension. Your car looks really good I do like how the front is lower than my car, I would prefer this look over mine. I will go will HR sport spring. Im only a .25" drop in the rear. I have 255/35/18 in the rear and I am concerned with rubbing. I have also read mixed reviews on sport struts being to soft and the car may rub. Have you (or anyone) expierenced this?
Old 05-19-2010, 11:41 AM   #4
arsevader
Originally Posted by nachos23 View Post
A couple of points:
Why would they be rough? Sports and HD have the same valving.
Sports are made for a drop while HDs are made for stock springs though the H&R sport spring is so mild that HDs would probably still be fine.
'85 325e
'90 325i
'02 325it
'03 320i
'96 Volvo 850R
arsevader is offline   Reply With Quote
Old 05-19-2010, 04:47 PM   #5
nachos23
SweetXi
nachos23's Avatar
Ya, but since he's looking @ the H&R springs, they lower 1.2" and specifically mention for lowered suspensions. H&R make a set for stock suspensions as well, but with the milage, the stock struts will likely not support it... (I know I tried initially)......
You may be right with the HDs, I was thinking race not HDs. Haven't actually ever seen someone use the HDs; see alot with Race and they always complain about ride comfort.
My Rides:
2009 335Xi
520HP
H&R coilovers
BBS LM wheels
//M sport package
2000 Z3M
Conforti tuned
AFE CAI
Old 05-19-2010, 05:11 PM   #6
champ0202
You may be right with the HDs, I was thinking race not HDs. Haven't actually ever seen someone use the HDs; see alot with Race and they always complain about ride comfort.[/QUOTE]
If alot of people have the race and they complain about ride comfort why would you still be considering race and not HD? what is the benefit with sport over HD?
why can these things never be simple...
Old 05-19-2010, 09:37 PM   #7
arsevader
You guys are confusing springs with shocks.
Bilstein makes Sport and HD struts/shocks.
h&R makes Sport and Race springs
Both Sport and HD struts ride pretty stiff regardless of springs. If you want confort and performance then go with Koni Str.t or Koni Yellows.
The best comfort/performance struts are Koni FSDs but they are back ordered everywhere.
'85 325e
'90 325i
'02 325it
'03 320i
'96 Volvo 850R
