Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 05-29-2011, 02:28 PM   #571
doogee
doogee's Avatar
Originally Posted by BigD View Post
Moar info? No crank, no fuel, no spark, none of the above but won't stay running?
It cranks no problem, but I'm not getting any spark, and I don't think I'm getting fuel either.
Tried Crank sensor, checked fuses and relays. So Stumped. I'm about to change the wiring harness.
Dakar M3 Track Build Thread
Old 05-29-2011, 03:39 PM   #572
SamE30e
SamE30e's Avatar
Hooked the cam and crank up backwards?
Check the resistance at the crank sensor should be 580ohms I think.. (the bentley is wrong)
85 325 - Turbo M52B28.
Old 05-29-2011, 04:55 PM   #573
doogee
doogee's Avatar
Ya the motor wouldn't of run before if they were mixed up. So it isnt that. Resistance on the crank sensor is ~530
Old 05-29-2011, 06:35 PM   #574
doogee
doogee's Avatar
So I decided to boost it with my car and it started right up this time. Idle is perfect but once you try revving it, it's missing like crazy. Also for some reason the hazards are on when the engine is running. They aren't blinking but just on. Thinking there might be a short somewhere but I don't have any blown fuses.
Old 05-29-2011, 08:15 PM   #575
doogee
doogee's Avatar
Car is all fixed. Turns out it was just a bad ground in the back of the car all along. Ground just happened to be for the fuel pump and also the hazards. So the connection was slightly loose, causing the fuel pump to run intermittently and as far as I know, if the pump isnt working, you dont get park. So all is good now!
Old 05-29-2011, 09:11 PM   #576
davericher20
black and blue
davericher20's Avatar
that's awesome, I should've remembered I didn't tighten down the ground lmao.
Old 05-29-2011, 10:49 PM   #577
dble Trouble
TAKE IT TO THE TRACK
dble Trouble's Avatar
^^If anyone it WOULD be you!!! LOL. ^^
Old 05-29-2011, 10:55 PM   #578
dble Trouble
glad you figured it out!
Old 05-30-2011, 11:42 PM   #579
davericher20
black and blue
not
helpful
Old 05-31-2011, 04:09 PM   #580
doogee
doogee's Avatar
Yellow M3 + Cayuga = Tomorrow
Old 06-02-2011, 03:35 AM   #581
'Whats seems to be the problem sir?'
"Your car is too loud"
'What?'
"Too loud! Well over 102db, there's no exhaust on this thing!"
'HUH?'
Loooooooolllllllllllllll. TMP FTL
Old 06-02-2011, 04:42 AM   #582
doogee
doogee's Avatar
'What?'
'HUH?'
Hahaha yeah, that put a big downer on the day. Basically got 4 or 5 decents laps in until I wasn't allowed back on because of the exhaust
Also ended the day going off and ripping the front Reiger lip to shreds. Went into the turn after the chicane pretty hot and the brakes weren't working as they should. Went into mad understeer and I didn't correct it properly
But at the end of the day, even just getting a few laps in was great. Car feels really solid but I definitely have a brake issue. The ABS cut out twice on track and definitely feel like the need to be bled again. I just need to get that sorted, plus a proper alignment and a muffler. Then I'll be back out!
Here are a few pics Will took. I'll upload some GoPro footage later.
Old 06-02-2011, 09:38 AM   #583
Yeah that was a shitty buzz. Your car sounded wicked out there.
Old 06-02-2011, 09:43 AM   #584
sb_600
sb_600's Avatar
Glad to see it's on the track!
Even with my muffler, I was too loud at CMP - I'm looking at getting a second muffler now to run in place of the resonator. Good luck!
Shawn
Old 06-02-2011, 01:06 PM   #585
BigD
the misanthropist
BigD's Avatar
Too loud on a track that's beside a dragstrip... riiiiiight. I guess they're now scared to go the way of Dunnville.
