11-01-2010, 06:56 AM
#136
Stance is Gay.
Car: '06 325i
Currently waiting on:
Bimmerworld Oil Distribution Block
Bimmerworld S50/S54 Oil Diverter Valve (to replace the stock thermostat)
Oil Cooler, lines, fittings etc
VDO Gauges and Senders (Oil Temp, Oil Pressure, Water Temp)
11-01-2010, 10:21 AM
#137
Car: God's Chariot
This thread needs more:
#138
Stance is Gay.
Car: '06 325i
Lmao
11-02-2010, 09:32 PM
#139
Stance is Gay.
Car: '06 325i
Today I mounted the coolant tank. Got the special brackets to mount to the chassis. They're supposed to be welded in, but since I don't have access to a welder, I use rivets and bolts instead. Rock solid.
I had to move the battery post back to the OBDII position since the tank is in the way. So I also extended the OBDI wiring harness to reach.
11-02-2010, 09:43 PM
#140
TAKE IT TO THE TRACK
Car: F30, E30
Kurt after seeing how awesome your 328 was on the track, this thing will be a monster! I'm looking forward to seeing you in this next year. I really like the quality of the parts you are using, you're not "cheaping out" just because. Good show!
BMW F30 335i M-sport - SerpaBMW Company Art car
BMW 325I E30 Track Rat
VW JETTA 1.8T WAGON Family Hauler (sold)
HONDA ODYSSEY 2nd Family Hauler (sold)
11-02-2010, 09:48 PM
#141
Stance is Gay.
Car: '06 325i
Yeah it should be a real fun toy!
I learned not to cheap out on these kind of things when me and a friend built up an S14 240sx two years ago. Chinese parts. Engine was done 15 minutes into it's first track day due to a pretty massive cooling system failure.
So while it's more expensive, I have a lot of time to finish and a lot of saving to do. But in the end, should be a bulletproof track car.
11-03-2010, 08:51 AM
#142
Stance is Gay.
Car: '06 325i
I like this switch layout:
11-03-2010, 09:28 AM
#143
formerly e36.M52B25
Car: 04 330ci
hahahaha
|M52B28 Swap|M3 Cams|BC Racing Coilovers|
|Full M3 Exhaust|M50 Manifold Conversion|3.38 LSD|
|Genuine 18" M-Parallels Non-staggered|Genuine 17" Style 5's Non-Staggered|Genuine Staggered 17" M double spoke Forged|
|MarkD Software|OEM lip spoiler|
|DJAUTO eurospecs|4500k HID| MyCarr CCFL AE|
|MCS Mini ITX 'carputer' Running Centrafuse 2.0|7" Lilliput Touchscreen|
|Viper 5901 Security System|
11-04-2010, 12:05 AM
#144
Stance is Gay.
Car: '06 325i
Todays work included changing out both Fuel Senders and the 95+ style siphon out for the Pre-95 style.
The reason is because the car will starve for fuel on hard right turns. So I either had the option to buy a Bimmerworld kit which includes two fuel pumps, or just convert to the 92 style which is just a better siphon system.
I don't know how effective this will be compared to the Bimmerworld kit, but we'll see in the spring!
11-04-2010, 08:27 AM
#145
Formerly Flav_cool
Car: '98 328is + '94 325i
You've felt the 328 starve for fuel on hard right turns?
1998 BMW 328is - summer
1994 BMW 325i - daily
1992 BMW 325i - totaled
1988 Mercedes Benz 190E 2.3-8V - sold
11-04-2010, 08:50 AM
#146
Stance is Gay.
Car: '06 325i
Yup it's actually undriveable once the tank drops below half.
11-04-2010, 10:20 AM
#147
Car: 320i
^^ yup, annoying as balls!
I found a solution for e46 non m's which have the same problem, I just havent got around to it yet. Not sure if it will work for e36 tho, but it is a cheap option to give a try.
http://www.e46fanatics.com/forum/sho...d.php?t=687864
11-04-2010, 02:20 PM
#148
Car: 91 318is,93 325is...
looks good, but rivits could shear with vibration over time, could try the threaded inserts and bolts kit from PA. Looks like it may hamper access to the computer
11-04-2010, 03:45 PM
#149
Stance is Gay.
Car: '06 325i
I'm pretty confident they aren't going anywhere. Even if they did manage to break off, it's not like the tank is going anywhere. You could literally rest it in there without mounts haha. Also it isn't a solid mount, there is plenty of play between the bracket and tank to absorb anything like that.
It isn't in the way of the computer any more than the air pump was. The tank pops off the mounts for more access anyway.
11-04-2010, 03:54 PM
#150
Car: God's Chariot
There isn't any tension on those brackets, so why on earth would they break? Rivets main purpose is to hold shear loads anyways. If planes are riveted together, pretty sure it can hold an expansion tank with less than a liter of fluid.
