Old 05-22-2010, 01:28 AM   #16
taxi615
lol I didnt know it was you...lol
PM me your number I will swing by to see ya!
BTW guy's I dynoed the car tonight Keep in mind the motor is 13 years old and that it is completely stock.
I made 236 RWHP at 60xx RPM corrected it gives me about 246 RWHP
I could have done higher but at high RPM's the octane dropped (91 of Québec shit gaz)
with VP racing fuel I could get and extra 10 to 15 RWHP
the printer was down they will email me the dyno sheet so I will be able to put it up here and show you guy's the numbers. very nice curbe to.
At my big surprise the car is still in perfect shape and running really strong. I did a compression test this morning and it's still 192 (lowest) to 195 (highest) PSI on all 6 cyl.
thanks for dropping bye
taxi615 is offline   Reply With Quote
Old 05-22-2010, 02:24 AM   #17
blk325i
blk325i's Avatar
what engine do you have in there?
i've never seen a stock s52 come near those numbers
blk325i is offline   Reply With Quote
Old 05-22-2010, 01:10 PM   #18
taxi615
It an Cdn 240 hp
motor. S52 if my memory serves me right
Old 05-22-2010, 04:55 PM   #19
taxi615
But i do have a question
When in traffic my bimmer starts to overheat the fan won't start unless i'm moving.
Do I need to install a switch for the fan? Or is it something else?
Old 05-22-2010, 07:31 PM   #20
iverson03tj
iverson03tj's Avatar
Which fan are u talkint about the belt driven or the auxilary fan?
Old 05-22-2010, 09:57 PM   #21
taxi615
Well it's the one for the coolant nut sure which one
Old 05-23-2010, 01:57 PM   #22
Walkman
Change ta clutch de ton fan (beltdrive) ou sinon c'est ton thermostat qui est bloqué
Je connais un gars qui est allé chez VSR pour faire poser son SC kit AA sur son E46, il semble sortir de bon chiffres. Reparle moi de cette shop la
PM moi les specs que tu vas faire sur ton block, j'y songe moi meme aussi un jour mais pas pour aller FI
Tu as fait flarer en arrière, ou as tu pris tes pieces, c'est des fenders de M3 E46 ?
Walkman is offline   Reply With Quote
Old 05-23-2010, 03:13 PM   #23
taxi615
ouin j'ai ben penser que ca serai une de ces deux pieces la. je vais checker ca quand je peux cette semaine.
oui ce qui est de VSR ces hautement les meilleur pour les européen en ville ces tous eux qui vont monter mon kit la tete je vais surement tous faire envoyer mon kit a VAC motorsport au USA je vais avoir un moteur blindé.
ce qui est du flare ca va aller a cette hiver car j'ai pas choisi encore mes roue pour l'été prochain je suis indécie entre du 10po ou 11po ce que je vais faire parcontre ces une réplique (en metal) des ailes E46 deux choses que je veux pas ces que ca frotte et que ca la lere foue...lol...alors mon gars de body va s'arranger avec ca.
Je tais envoyer un pm ca serai pas pire de rider enssemble je connais pas ben ben de gars avec des E36.
Old 05-23-2010, 03:40 PM   #24
taxi615
here is the finished results of my front end with reiger lip on. I will take more when the car is completly clean and in a better area.
BTW dont pay attention to the VSR and monster stickers I doing they are temporary its for a rally across qc soon. they will be off when I'm done.
I'm open to positive or negative comments!
Old 05-28-2010, 01:34 AM   #25
taxi615
hey guy's I was thinking could it be my water pump that failed???
thermostat the car would get stuck on cold...
and the clutch fan is free...
so after ready a few things the water pump is the only logical thing left. if the impeler is broken the thread was saying that the coolant would not reach the motor when the car is running...but when rolling the fan is turn as wind is hitting it...could this make sense???
Old 05-28-2010, 09:55 AM   #26
Daneee
be cool
Daneee's Avatar
Send a message via MSN to Daneee
maybe you have some air in the coolant line...
if is the water pump you have overheating anytime
suck the fish
Daneee is offline   Reply With Quote
Old 05-28-2010, 09:59 AM   #27
taxi615
ok
I will be taking all of it apart this weekend so I will see what is not working for me
Old 05-31-2010, 11:59 AM   #28
taxi615
Ok after checking all my system I ended up flushing my coolant and all is perfect so I'm guessing it was just bad coolant I'm happy to see that I didn't need to change any parts.
I will upload also pics from my rally this weekend across the Quebec province.
Old 06-01-2010, 12:29 AM   #29
taxi615
pics I took on my run in qc this weekend.
all the stickers are off now nice and clean...lol
Old 06-01-2010, 12:33 AM   #30
taxi615
I'm also woundering if I should get black kidneys or keep em chrome give me your opinion guy's
BTW BF KDW are awsome they grip like hell I do recommande to all but they dont come cheap. 255 R 235 F
