Old 05-02-2010, 09:36 PM   #1
Brent
Brent's Avatar
No Start Issue (Part 2!)
Hi guys,
My car started up today, then died when it was running.
I wasn't able to restart it.
So, we tried the following:
1. Checked the rotor, it seemed ok.
2. Checked for a spark, didn't get one. (pulled the wire, grounded it to a shock tower.)
3. Checked for fuel, weren't getting any. (pulled the fuel line, it was dry)
4. Pulled the fuel pump, hooked it to a battery, it is working fine.
5. Checked both wires to the pump, one showed electricity, the other didn't.
My basic question is: what would stop power from going to the fuel pump and also the distributor?
Thanks for your help...
Brent is offline   Reply With Quote
Old 05-02-2010, 09:46 PM   #2
Main fuel pump relay in the engine bay.
Dare I squeeze
Old 05-02-2010, 09:52 PM   #3
Brent
Brent's Avatar
Trevor,
Where is it located? In the middle or on the left of the three relays?
Old 05-02-2010, 09:53 PM   #4
Brent
Brent's Avatar
Also, would that affect the lack of spark?
Ok, I also switched the two relays that were the same under the cover around, still no hum from the fuel pump...
Old 05-03-2010, 07:27 AM   #5
In the engine bay on the left strut tower. One is the main relay which gives power to the ECU, give it a few taps with the ignition on. One is also a fuel pump relay.
A bentley manual would be useful in this case, I believe it tells you how to test for power at the fuel pump, but I can't remember the procedure off the top of my head
Dare I squeeze
Old 05-03-2010, 10:42 AM   #6
Boxer2
A true enthusiast
Boxer2's Avatar
Have you inspected the main 50 amp fuse? If this fuse goes, the fuel pump will not operate, nor will you have any spark, the engine will still crank over while operating the starter, but will not start. The fuse is located on the positive lead about a foot away from the battery, you will have to cut the wire casing and spread it open to get to the fuse.
[SIGPIC][/SIGPIC]
My Garage:
1986 328is (M20 Stroker)
1986 535i (5sp all original)
1990 325iX (Mint 5sp all original)
1989 325iX (Winter auto X car)
1991 M5
1988 M6
2001 740i (Supercharged)
2004 X5 3.0i (The DD)
Boxer2 is offline   Reply With Quote
Old 05-03-2010, 10:47 PM   #7
Brent
Brent's Avatar
Ok guys, problem solved. Not sure exactly what caused the no spark issue, but I replaced all 3 relays, and the car started right up, and ran fine. I also tried a few other starts, no trouble at all. If I had to guess, I would say that Trevor was definitely right about the fuel pump relay, and maybe there was a problem with another relay as well. Funny, I thought this was a bigger problem than just plugging in some relays...for the first time, an issue solved that took less work than expected...lol
Thanks again for your help, guys.
