Old 04-29-2010, 11:48 PM   #1
doogee
doogee's Avatar
Wink Roll Cage : Need Piping
Anyone know of any pipe suppliers?
Building a cage for my track car very soon and need a hookup.
Dakar M3 Track Build Thread
Old 04-30-2010, 12:32 AM   #2
SamE30e
SamE30e's Avatar
Metal supermarket. Just make sure you get the right material and thickness. Track officials are very picky.
From what I hear it's a pretty standard size.
85 325 - Turbo M52B28.
Old 04-30-2010, 02:24 AM   #3
What he said. Generally, it will be 1.5x.120 pipe (depends on weight, but you will need a fairly serious weight reduction done on the E36 to get it to the next weight level than requires the smaller tubing)
Old 04-30-2010, 02:28 AM   #4
doogee
doogee's Avatar
Thanks guys! Metal Supermarket is a block away from where I'm building the car!
I highly doubt I'll be getting under 2500 lbs.
Where is the best place to put a hole for inspection?
Old 04-30-2010, 02:40 AM   #5
You will need to drill an inspection hole around the bottom of every main post. So say, front hoops, and main hoop? something like that. The CASC rule book may specific an exact spot, don't remember offhand.
Old 04-30-2010, 09:43 PM   #6
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
I hate to say it, but isn't this one of those things that if you need to ask, you shouldn't be doing it yourself? Safety is no joke.
Old 04-30-2010, 09:46 PM   #7
doogee
doogee's Avatar
Oh I wouldn't know where to begin if I was doing it. That's why I'm having my brother do it. He has a lot of experience welding. Been doing this kind of stuff for years.
Old 05-01-2010, 11:07 PM   #8
exbmwtech
Are you building your car for track days or casc regional racing... if so you can find the cage material thickness and other useful info in the casc race regulations rule book
http://www.casc.on.ca/documents/race/2010raceregs.pdf.
Do you have a cage designed if you need ideas....you can look at mine ( e36 coupe) Iam in Toronto.
exbmwtech is offline   Reply With Quote
Old 05-02-2010, 02:05 AM   #9
doogee
doogee's Avatar
Thanks, already been there Got all the specs. I'm not going to be racing competitively for a year or two so I'm building the car for fun right now but to Prepared spec for the future.
And for design ideas, im pretty set on a design. Do you have a full 6 point? because that's all I'm interested in.
