Old 04-29-2010, 10:09 AM   #1
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
Send a message via MSN to AlpWhitE46
Car not starting
So after being excited about installing some goodies yesterday including new angel eyes, i try to start the car today in the morning and it wont turn on.
Its turning normally but just wont start.
However i have had this problem happen about like 5 times in the last year and a half randomly... but somehow after enough turning it would just start ...
I think this is mostly likely the Vanos (iv been driving around with he check engine light which said that...but the car was still turning on pretty normally)
I was going to order the Beisan stuff to do it but never got around to it.
Is it very possible my car isnt turning on because of this?
Or should i replace the camshaft/crankshaft sensors? Has anyone done the camshaft sensors replacement?
AlpWhitE46 is offline   Reply With Quote
Old 04-29-2010, 11:11 AM   #2
MarkD
MarkD's Avatar
Not likely at all that it is the VANOS, but it could be the camshaft sensors. Or something else.
Old 04-29-2010, 11:24 AM   #3
INFAMOU$
Automotive Puppeteer
INFAMOU$'s Avatar
If it is one of those sensors then you should have a CEL for them. If you have had this issue in the past and the car would start after lots of turning over... I would recommend trying to turn your key on (but not to the start position).. wait 3 seconds (for the fuel pump to prime) then turn off, repeat this 3 times in a row and then try to start the car on the 4th turn. If it starts then fuel pressure is your issue and you will need to replace your pump.
Vanos will not cause your car to not start...
Old 04-29-2010, 12:03 PM   #4
NOTORIOUS VR
NOTORIOUS VR's Avatar
you need to check the basics first... check for fuel and spark.
Old 04-29-2010, 12:10 PM   #5
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
Thanks infamous i'm giong to try that in a bit... EDIT: nope didn't work... im almost 95% sure its the camshaft sensor =(
Has anyone changed it before?
Old 04-29-2010, 12:16 PM   #6
NOTORIOUS VR
Get it scanned before you start throwing parts at it.
Old 04-29-2010, 01:27 PM   #7
magnus
magnus's Avatar
I think your ground somewhere is not ok.
If you were messing with electrical stuff then it sounds more likely.
Maybe you should leave it overnight with the ecu unplugged and then run it so it has reset.
I doubt its the vanos though and CEL is a very good point too!
http://pics.livejournal.com/blblblblx/pic/000r554e.gif
"Lo there do I see my father.
Lo there do I see my mother.
Lo there do I see my brothers and my sisters.
Lo there do I see the line of my people back to the beginning.
Lo they do call to me
they bid me take my place among them in the Halls of Valhalla,
where the brave may live forever"
magnus is offline   Reply With Quote
Old 04-29-2010, 02:14 PM   #8
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
Notorious, i checked a while ago it was codes 102 and 104 when check engine was on (and still is on) for blocked vanos and something else camshaft. . .
Anyone live around etobicoke that could come check it out for me? I'm not really good with the electrical stuff..
What is CEL btw?
Old 04-29-2010, 02:50 PM   #9
kevin325
AMG ETR
kevin325's Avatar
Check Engine Light
kevin325 is offline   Reply With Quote
Old 04-29-2010, 02:59 PM   #10
INFAMOU$
INFAMOU$'s Avatar
If you had a code for something Camshaft related then sounds like you may have a bad sensor then. Not hard to replace. But again, double check the codes to make sure you know exactly what you need to replace!
Old 04-29-2010, 08:53 PM   #11
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
i checked code from this reader i got...
P0014 and P0015
14 = Cam position actuator B - Bank 1 timing over advanced
15 = Cam position actuator B - Bank 1 timing over retarded
Old 05-02-2010, 11:09 AM   #12
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
Change the exhaust one... car still does not start.
Still have the intake one to do but seems like an annoyance, i don't even have the 32mm
Unless anyone else has done the intake one before?
Old 05-02-2010, 01:06 PM   #13
pull a sparkplug, see if its wet.
Old 05-02-2010, 03:52 PM   #14
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
Just changed out intake sensor and car still wont start... ****!
I will try to get mechanic to come with the computer to reset ECU, see if it will do anything and if it reads out any other code...
Old 05-19-2010, 07:23 PM   #15
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
Turns out the vanos is fully screwed up... oil all over there.
I need a new one will be ordering from drvanos.com
