Old 04-24-2010, 11:08 PM   #16
jamison67
E30 POWER
jamison67's Avatar
ya i have a fuel pressure gauge instaled and am running about 45psi and rising it back and forth to between 45 and 50 just to see where i get the best ratios from,,,,i am running th 24 pounder injecters from ford,,and the stock fuel pump that was new last year so should still be in good working order,,,,,,if u look on paper it seems that everything should be good but its not i just cant get enough fuel in there to run her rite ,,shes running to lean then when i tuen the fuel up it dosnt want to start with ease
jamison67 is offline   Reply With Quote
Old 04-26-2010, 07:29 PM   #17
jamison67
E30 POWER
jamison67's Avatar
anybody have any ideas as to what happening here
Old 04-26-2010, 07:36 PM   #18
NOTORIOUS VR
NOTORIOUS VR's Avatar
you haven't given us any solid info to help you with.
You're using the worst thing you possibly can when it comes to boosting a car, a RRFPR.
You say you have a wideband? Start logging and post up the results.
E36 DYNO TUNING WIRING PARTS
Old 04-26-2010, 07:51 PM   #19
MarkD
MarkD's Avatar
What's happening is what happens to everyone when they use a RRPR and don't perform any fuel adjustments in the chip. Did you say that the motor cut out when you were in boost? That happens when the DME sees an airflow that is bigger than it should ever see when normally aspirated. There is a certain limit programmed in the DME and when it is exceeded, it just cuts out. That may be what happened. I didn't put that fix in the TCD chip as he did not ask for it.
If you want to come over one Saturday or Sunday when I have a few hours, I'll try to fix it up, though it may take a few visits to get completely right as I can't spend all day on it on one single weekend.
Old 04-26-2010, 11:14 PM   #20
jamison67
E30 POWER
jamison67's Avatar
im busy this week wit work so this weekend im going to log the afr and post them,,i wanna go megasquirt but im reading up on it all over the place and it just not sinking in for me in understanding the tuning process and hooking it to getting the car running and stufff like that so im a bit timid ,,,,,,in your opinion was it easy to do them u first thought it would be to hook it and tune the car proper?
markd,,,it dosnt cut out when the boost kicks in ,,,,its right before it kicks and then when it kicks it just leans right oout at one point my waste gate lt about 10 psi in and the wide band went up to in the 14s ,,,,no good ,,,so i need help here to fix this or im going to be building a motor in a few weeks
Old 04-26-2010, 11:54 PM   #21
NOTORIOUS VR
Don't take this the wrong way, but it sounds like you're in way over your head with this project.
You need to do one of two things.
1. Take the car to someone who knows how to make it run somewhat decent with your setup.
or 2. Do a lot more reading/searching of the forums that deal with a setup similar to yours and gain a hell of a lot more knowledge then you have now to deal with it yourself.
If you thought that building a boosted car on your own, slapping in a chip and RRFPR and calling it a day you were very mislead.
Most if not all of your questions have been asked and answered on e30tech.com, I see you made a thread there as well, but what you fail to realize is that people can only help you solve something when you somewhat know what to do yourself and give enough useful info of what is happening and when it's happening.
Hope that clears it up a little. I also agree that MS isn't something you should take on by yourself. There are people in the GTA that know how to do it, so maybe you should try to contact them (or find them) and see what it will cost you. Or, like I said before take up MarkD's offer and have a car that runs like a stand alone would but on a OEM computer.
May things to consider here.
