Old 04-21-2010, 09:44 PM   #1
Steve30
Techno Viking
Steve30's Avatar
RSM's
What rear shock mounts should I go with? I'm throwing on the coilovers but I want to make sure the rear shock towers don't get torn apart since it will be pretty stiff. OEM with the z3/4 reinforcing plates? or would a monoball setup be worth it?
Steve30 is online now   Reply With Quote
Old 04-21-2010, 10:35 PM   #2
I went with Meyle HD shock mounts and the reinforcement plates, unless you plan to track your car alot, I don't think the solid mounts are needed. Plus solid mounts usually produce increased road noises.
The HDs are cheap and easy to replace, so I don't mind if they don't last a lifetime.
What coilovers did you go with?
Old 04-22-2010, 02:52 AM   #3
Steve30
Techno Viking
Steve30's Avatar
KW V3's
Old 04-22-2010, 12:44 PM   #4
Dysantic
Captain Chaos
Dysantic's Avatar
Where would one go about getting thise shock mounts? And how much would they cost? I just picked up a set of coilovers as well and was thinking it might be a good idea to replace the mounts and other stuff on my suspension that is 13 years old.
Old 04-22-2010, 01:49 PM   #5
Steve30
Techno Viking
Steve30's Avatar
TMS, they have a few styles to choose from.
bearing - http://www.turnermotorsport.com/html..._ID=TSU9906SM1
HD - http://www.turnermotorsport.com/html...ID=33521132104
aluminum- http://www.turnermotorsport.com/html...T_ID=TCKRUM12R
Old 04-22-2010, 02:10 PM   #6
Steve30
Techno Viking
Steve30's Avatar
Anywhere I can get GC RSM's locally? After some searching/reading I think they would be the best choice.
Old 04-22-2010, 02:13 PM   #7
hockeyfan27
hockeyfan27's Avatar
aluminum stock size 10mm: http://www.turnermotorsport.com/html...DUCT_ID=JTD909
1998 328ic - Sold
hockeyfan27 is offline   Reply With Quote
Old 04-22-2010, 02:15 PM   #8
Steve30
Techno Viking
Steve30's Avatar
The GC's look pretty beefy and you can remove the rear shock a lot easier since the bolts are upside down.
Old 04-23-2010, 02:04 AM   #9
Dysantic
Captain Chaos
Dysantic's Avatar
Are the front and rear mounts the same? Anyone know of a local place to get these rather than wait for shipping?
Old 04-23-2010, 09:21 PM   #10
Steve30
Techno Viking
Steve30's Avatar
Front mounts are totally different and I'd like to know if there is a local supplier as well.
Old 04-23-2010, 09:22 PM   #11
Dysantic
Captain Chaos
Dysantic's Avatar
Would replacing both the front and the rear mounts be a good idea, or are the rears the ones that need the most attention?
Old 04-23-2010, 09:23 PM   #12
Steve30
Techno Viking
Steve30's Avatar
The rears are considered a maintenance item and I don't think the fronts need to be replaced.
Old 04-24-2010, 05:29 PM   #13
Steve30
Techno Viking
Steve30's Avatar
Bump, nobody knows where I can get the GC's locally? I know somebody knows!!
bimmerworld has them for a good price but UPS will rape me as usual
http://store.bimmerworld.com/ground-...neal-p106.aspx
Old 04-29-2010, 09:43 PM   #14
QcE36
if you want to reinforce the front i have M3 front reinforcement plates + gasket, never used.
QcE36 is offline   Reply With Quote
