Old 04-09-2010, 01:08 PM   #1
Hurricane240
Hurricane240's Avatar
Hunter 9700 Balancer in Milton
Anyone know a shop in the area with a Hunter 9700 tire balancer??
Hurricane240 is offline   Reply With Quote
Old 04-09-2010, 01:09 PM   #2
Hurricane240
Never mind... found out hunter has a website search for this!
http://www.gsp9700.com/pub/search/Fi...ons_Canada.cfm
Old 09-05-2010, 02:26 PM   #3
Mover
That lists all retails having ANY type of hunter balancer. They don't limit it to the 9700.
Mover is offline   Reply With Quote
Old 09-05-2010, 03:22 PM   #4
MarkD
MarkD's Avatar
Are you sure?
Then what does this statement from the website mean ?
Locate A GSP9700
This service is only available for locations within the United States, Germany and Canada.
Old 09-05-2010, 04:09 PM   #5
Quack
Wheelman
Quack's Avatar
our dealership has one, but isn't listed on their search
Old 09-05-2010, 04:38 PM   #6
MarkD
MarkD's Avatar
Maybe that is because the dealership most likely works only on MB cars.
Old 09-05-2010, 05:37 PM   #7
Quack
Wheelman
Quack's Avatar
yeah so, if you check the search feature it comes up with a lot of dealers, including Parkview BMW, Honda, Toyota, etc, it pretty much list all the dealers using Hunter products, but for some reason our dealer isn't listed even though we have a GSP9700 Road Force balancer.
Old 09-05-2010, 07:54 PM   #8
What's the advantage to a hunter roadforce balancer? Every wheel i've balanced on a regular wheel balancer has been fine.
Old 09-05-2010, 08:50 PM   #9
SamE30e
SamE30e's Avatar
It puts a force on the wheel, to simulate the wheel being on the car. Makes for more accurate balancing.
85 325 - Turbo M52B28.
Old 09-06-2010, 10:40 AM   #10
damameke
is it more expensive using the hunter 9700 balancer then?
Old 09-06-2010, 11:09 AM   #11
Ceeker
not really...they bring a wheel down onto the tire while it spins up to determine/simulate road force on the wheel. this will tell you if they did a good job balancing it. Most guys don't bother to try and line up the rim with the tire to eliminate the need for more weights.
Of course no tire or rim is absolutely true so they try and get as close as possible. If they did a shitty job balancing it then either the tire is shitty, rim bent or both
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 09-06-2010, 02:49 PM   #12
I dont understand how this makes anything more accurate. Zero is zero, no?
Old 09-10-2010, 07:38 PM   #13
Mover
Are you sure?
Locate A GSP9700
Yes, I'm sure.
I looked into it and found that some of the listings they have don't use a Road Force GSP9700 balance machine. Some of them use Hunter equipment, although its not the 9700.
I'm also sure some of them are correctly listed as well.
Old 09-10-2010, 07:49 PM   #14
Mover
An out-of-round tire or bent rim could be 'balanced' on other balancers. The Road Force takes more factors into account.
Old 09-10-2010, 07:56 PM   #15
... so unless you bought a china tire which is a triangle instead a circle, you're good with a regular balancer?
