Old 04-22-2010, 03:58 PM   #1
digiital
digiital's Avatar
My gas usage the past few months.
I use a app on my iPhone called "Gas Cubby" to track my gas usage and thought I would share this with others on here.
I have a 2004 325i. With almost 97K on it.
On 2010-01-11 I installed a K&N filter to replace the standard BMW air-intake filter.
HTML Code:
L/100km	Date	Odometer	Filled Up	Cost/Liter	Liters	Total Cost	Gas Brand	Total Cost
0	4/19/2010	96,797	Full	$1.13 	58.501	$65.81 	Shell	$65.81
9.7	4/12/2010	96,192	Full	$1.13 	54.63	$61.90 	Shell	$61.90
10.5	4/5/2010	95,672	Full	$1.15 	53.632	$61.84 	Shell	$61.84
9.2	4/1/2010	95,090	Full	$1.14 	53.042	$60.41 	Shell	$60.41
10.4	3/27/2010	94,578	Full	$1.12 	57.293	$64.00 	Shell	$64.00
10.1	3/23/2010	94,008	Full	$1.13 	58.325	$65.67 	Shell	$65.67
9.7	3/15/2010	93,409	Full	$1.13 	55.423	$62.68 	Shell	$62.68
10.2	3/10/2010	92,866	Full	$1.14 	59.358	$67.67 	Shell	$67.67
10	3/1/2010	92,275	Full	$1.15 	58.077	$66.50 	Shell	$66.50
10.1	2/22/2010	91,700	Full	$1.12 	53.654	$60.20 	Shell	$60.20
10.3	2/22/2010	91,661	Partial	$1.12 	7.35	$8.25 	Esso	$8.25
10.3	2/16/2010	91,108	Full	$1.08 	45.83	$49.59 	Shell	$49.59
10.1	2/12/2010	90,655	Full	$1.08 	54.946	$59.56 	Shell	$59.56
9.9	2/8/2010	90,101	Full	$1.08 	59.013	$63.62 	Shell	$63.62
10.9	2/2/2010	89,564	Partial	$1.09 	29.543	$32.23 	Shell	$32.23
10.9	1/30/2010	89,290	Full	$1.09 	57.96	$63.23 	Shell	$63.23
10.3	1/23/2010	88,727	Full	$1.10 	55.731	$61.03 	Shell	$61.03
10.2	1/17/2010	88,181	Full	$1.11 	59.732	$66.00 	Shell	$66.00
10.6	1/11/2010	87,615	Full	$1.13 	59.114	$66.62 	Cdn tire	$66.62
11.8	1/9/2010	87,497	Partial	$1.14 	13.202	$15.01 	Esso	$15.01
11.8	1/4/2010	87,000	Full	$1.11 	57.619	$63.78 	Cdn tire	$63.78
11.4	12/30/2009	86,494	Full	$1.10 	55.92	$61.51 	Shell	$61.51
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.
Mark Twain
digiital is offline   Reply With Quote
Old 04-23-2010, 12:30 AM   #2
EMPIREM3
Catch me if you can.
Send a message via MSN to EMPIREM3
with the intake u getting more or less kms ?
///M Power
EMPIREM3 is offline   Reply With Quote
Old 04-23-2010, 10:49 AM   #3
digiital
digiital's Avatar
I haven't had the car a Looong time, but did noticed that when the filter was replaced it gave me a good 1L per/100 off the bat. But based on the cars display I'm right now getting about 9.3L/100 on average and when refilling the taken I've had it say I can get about 733km on the tank. My driving is a mix of 60% highway and 40% city.
Mark Twain
Old 04-23-2010, 06:24 PM   #4
Mikeee46coup
Your on par with most E46's that are well taken care of; you may however want to reconsider the K&N, independent test show they don't filter very well and can contribute to premature MAF failures (oiled filters).
Mikeee46coup is offline   Reply With Quote
Old 04-24-2010, 01:14 PM   #5
EMPIREM3
The cautionary post that K&N put out was about people adding excessive amounts of oil to the filter gauze after the 1st cleaning.
A regular cleaning of your air intake system, including your mass air flow sensor can be done at a regular interval.
///M Power
Old 04-24-2010, 02:44 PM   #6
Mikeee46coup
True (although not what I was referring to); but why make more work for yourself? MAF is a pretty sensitive and expensive component to risk unnecessary handling of.
What I was referring to was a few years ago an S.A.E lab tested the K&N filter median and determined that it was inferior to conventional non oiled filters (poorer filtration and air flow); the paper was never formally retracted but K&N's lawyers had it removed from SAE's online database and online publications (wish I had saved a copy of it).
