Old 04-03-2010, 08:45 PM   #1
elroy
taking apart help
hey guys quick questions about the e30.
1 - how do you unhook the front harnesses for the doors. I see a big white clip thing but no idea how to unhook it.
2 - how did you get the trunk off or more specifically how did you get the trunk light wire out, the only thing i can think of now is to cut the connector off. the wire is wedged between the trunk metal and the reinforcements.
3 - i have rust on the floors, any one know where i can get the metal sheeting, the cheaper the better. i've read 1.2mm is the correct thickness (or atleast thats the number that comes to mind.)
thanks
elroy is offline   Reply With Quote
Old 04-03-2010, 09:15 PM   #2
1. Peel the rubber boot back, there's a clip to pull and the harness unplugs.
2. Disconnect the battery, pull the light, unplug the wire from the light and pull the wire though from the hinge area.
3. Yellow pages will have lots of metal places I would guess, but I'm not sure. Your location doesn't reveal where you're from, so ?
Old 04-03-2010, 09:28 PM   #3
elroy
woops sorry, pickering.
the white clip has two tabs, i pressed them in but didnt have any luck. ill try again tomorrow.
Old 04-03-2010, 09:28 PM   #4
Buy somebody's spare E30 hood on here, and use that. Quality german metal on the cheaps
Old 04-03-2010, 10:22 PM   #5
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
Pull back the weather stripping, remove hood latch, remove speaker cover, remove speaker, reach in and wiggle the two door connectors apart... or pull harder. Kind of a PITA.
Grow up and move on.
Old 04-03-2010, 10:34 PM   #6
Ceeker
the door clip is always a pain; since moisture usually gets in and corrosion also sets in. You may want to spray lube in between the mating surface. Then take a set of needle nose or a couple vise grips- hold the tabs moving them together and wiggle side to side until it starts to back away. Eventually it will slide out. don't be surprised if you have a few green pins in there. That is corrosion. I had to replace all my pins at some point in my car. Hope this isn't the case with yours. Or as Scott mentioned you could try going in from the floor kick panel speaker side.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 04-03-2010, 11:16 PM   #7
elroy
Dam everything else is coming off relatively easy. Will def try to sep that white clip tomorrow.
Old 04-08-2010, 12:36 AM   #8
elroy
whats the odds of finding a rust free shell? the more i take mine apart the more it makes me dislike it. I see all these shells in the states but bringing it up here is a pita
looking for 91 318 shell or even one with blown motor....or with little rust
Old 04-08-2010, 12:40 AM   #9
You and a thousand other Ontario E30 owners. :p
Old 04-08-2010, 07:23 AM   #10
dannyb
ive seen the worse shell ever, it has no floor and no fenders. the guy searched for another shell in ontario and couldnt find one in decent shape, hes going to "rebuild" his shell. hes a member here, maybe ill get him to post some photos of the horror.
dannyb is offline   Reply With Quote
Old 04-08-2010, 11:44 AM   #11
elroy
lol honestly the more i tear into this the more i get discouraged. but then i look at other builds in ontario and realize mine isn't that bad. do they have to make so dam expensive and time consuming to bring a car into canada...grr!!!
Old 04-08-2010, 12:11 PM   #12
If your shell is really that rusty, you might spend more getting it rust free than spending a couple grand on importing one. Something to think about.
Old 04-08-2010, 11:20 PM   #13
elroy
gave that some thought but i dont know where to look for shells, or cars with blown engs. i took a quick look on r3vlimited but those are all proper cars.
Old 04-09-2010, 09:47 PM   #14
Brent
Brent's Avatar
Elroy, try Metals Plus in Whitby, that's where I got mine. They have a cheap off cut section in the back. I asked them what thickness to get, I think it was 20-22 guage or so...
Brent is offline   Reply With Quote
Old 04-09-2010, 09:48 PM   #15
Brent
Brent's Avatar
oops, I mean gauge!
