Go Back   maXbimmer Forums > Classifieds > For Sale > Suspension & Brakes
Old 04-01-2010, 03:07 PM   #1
hooked
FS Race Suspension Parts - Used 1 Day
Ground Control rear lower control arms:
Designed as a heavy duty replacement of the stock, flimsy "salad tong" arms.
The Ground Control arms incorporate a sealed inner bearing for extended use, street and track.
The arm set uses heavy duty chromoly for good strength and light weight.
They alloy further camber adjustability compared to the stock arms, allowing a large positive and negative adjustment range.
Arms are powder coated to resist corrosion.
Arms can be used with either a rubber outer bushing (stock on all E36 and E46 cars except 1996-99M3 and E46 M3) or upgraded spherical bearing outer (stock on 96-99 M3 and E46 M3).
Fits all E36 and E46 BMW 3 Series cars from '92-'06.
$325
TC Kline Racing Camber/ Caster Plates - TCKR High-quality aluminum alloy, easy to adjust camber/caster plates are unlike anything else on the market!
They work equally well with stock or aftermarket struts including Coil Over configurations without the need to purchase additional parts.
In most cases you can use our camber plates with stock springs or lowering springs such as H&R, Vogtland, or Eibach.
Our camber plates assure you of significantly improved turn-in and will not harm ride comfort.
They feature lightweight, durable, aluminum alloy construction, highly protective anodized coating and a spherical ball joint, (replaceable), offer crisper,
quicker steering feel. We have incorporated a “load ring” into the top of the camber plate to reduce stress on the sheet metal in the strut tower of the car.
$500
Monoball Rear Upper Shock Mounts. Use with any 10mm std adjustable shocks. For track/street use (pair) $150
E46, E36, E30 all Rear Spring Ride Height Adjuster (pair)$150
hooked is offline   Reply With Quote
Old 04-03-2010, 11:04 AM   #2
sparkybp
Tortures BMWs.
sparkybp's Avatar
It looks like these arms already include the spherical bearing throrough which the camber would initially be adjusted. Or will they be removed prior to sale?
Old 04-03-2010, 03:03 PM   #3
hooked
Not sure what bearing you are speaking of. They attach at the frame by the diff and down at the bottom of the wheel assembly. They simply replace the existing stock lower control arms.
Old 04-03-2010, 04:41 PM   #4
Royksopp
Royksopp's Avatar
will tc kline camber plates fit e36??
Royksopp is offline   Reply With Quote
Old 04-03-2010, 05:34 PM   #5
hooked
Yes , they were on a 93 325is
Old 04-07-2010, 11:35 AM   #6
hooked
Photo of Camber Plate assembly
Old 07-29-2010, 01:18 AM   #7
doogee
doogee's Avatar
Do the camber plates come with Perches? 60mm?
Dakar M3 Track Build Thread
Old 12-02-2010, 04:27 PM   #8
hooked
Control Arms Gone
