Old 03-30-2010, 08:33 PM   #1
Steve30
Techno Viking
Steve30's Avatar
side skirts
This might sounds like a dumb question but I want to do it right the first time and not screw anything up. I removed my sideskirts to check if any dirt buildup was there and prevent rust since it is a common problem on E36's. Now, I need to install them but before I do whats the easiest way? Should I attach the clips to the sideskirt and then press them into the grommets or attach the skirt to the clips while they are on the rockers?
E36 ///M3 S54
STock 335i "The Punisher"
Old 04-05-2010, 09:33 AM   #2
Darkness95m3
Darkness95m3's Avatar
Originally Posted by Steve30 View Post
Should I attach the clips to the sideskirt and then press them into the grommets?
That is what I would do.
Old 04-05-2010, 10:07 AM   #3
Steve30
Techno Viking
Steve30's Avatar
I actually put them back on and it was easy, I didn't break any clips either. I pressed all the clips into the grommets then just attached the side skirt one clip at a time.
E36 ///M3 S54
