Welcome to!
Old 03-25-2010, 12:54 PM   #1
hockeyfan27's Avatar
Aux fan testing
So I think my AUX fax is dead but I want to be sure before I go about replacing it.
When I turn on my A/C it should come on, correct?
1998 328ic - Sold
hockeyfan27 is offline   Reply With Quote
Old 03-25-2010, 01:21 PM   #2
Dr. Flyview
Dr. Flyview's Avatar
Yes, I believe it should. Make sure you check the fuse, and try a different one even if it looks ok.
Another way to test is to disconnect the temp sensor that turns it on (plugged into passenger side of radiator) and then play with the 3 holes it has. When you connect 2 of them, it should turn on. I don't think you can harm anything by trying all combinations, there's 2 positives (2 speeds) and 1 ground/negative. You short circuit the switch basically, not the radiator itself.
1998 BMW 328is - summer
1993 BMW 525i - sold
1994 BMW 325i - sold
1992 BMW 325i - gone
