Old 03-24-2010, 11:50 PM   #1
proudbmwownr
where to get the pully holding tool for clutch fan ?
hi there everyone i joined a couple of months back but this is my first post..
i need the tool to hold the pully while i take the clutch fan. i tried a screw driver but that got bent.
i need to get the clutch fan out to reseal the thermostat housing.
any places that sell them other than the stealership ?
maybe even someone local can let me borrow it ?
i tried ebay but shipping costs like $20 for canada lol
i already got the 32 mm wrench from princess auto.. but they dont have the pulley holding tool
thanks everyone
proudbmwownr is offline   Reply With Quote
Old 03-25-2010, 01:00 AM   #2
blk3
blk3's Avatar
personally i bought a matco set that allows you to attach an air hammer at the end which makes removing clutch fans a snap. costs a bit ($250) but thats with all the adapters and hard case. much cheaper if you buy the wrench you need and the air hammer adapter piece. works great and worth the money.
Old 03-25-2010, 01:05 AM   #3
steve.325i
thanks everyone
I ordered mine for way too much money from bimmertools in the states and paid more then that in shipping brokerage & taxes. Then I see on the packaging that it is also good for 4.3L & similiar GMC and Ford trucks.
They sell ones for Domestic trucks at Partsource.
steve.325i is offline   Reply With Quote
Old 03-25-2010, 10:06 AM   #4
INFAMOU$
Automotive Puppeteer
INFAMOU$'s Avatar
lol.. a hammer on the wrench works fine.. Save your money. Just remember that clockwise = loosen.
Old 03-25-2010, 10:33 AM   #5
proudbmwownr
i hammered the shit out of it yesterday and it wouldnt budge.
it would move but moves the pulley with it
i guess im gona check out partsource
thanks everyone
Old 03-25-2010, 11:28 AM   #6
INFAMOU$
INFAMOU$'s Avatar
Spray it with liquid wrench first and let it sit (don't get it on the belt).. Better yet.. also, get the engine nice and warm for a bit (after driving for the day) then try it. I am sure it will come off!
Old 03-25-2010, 11:33 AM   #7
archrival
E36 Addict
archrival's Avatar
^ What he said. You may have to hit it with the hammer ten times but it will come loose. Also make sure you are using a decent sized hammer and going clockwise to loosen.
archrival is offline   Reply With Quote
Old 03-25-2010, 11:44 AM   #8
hockeyfan27
hockeyfan27's Avatar
i had the same issue with the pulley slipping in the belt. I even removed the belt and used one of those strap clamp things and had no luck.
I eventually made my own tool. I took a piece of steel, drilled 2 holes in it (spaced to allow me to bolt it to the pulley using 2 of the 4 bolts that hold it on) then I went to town with the hammer. I only went this route as partsource had already lent out the tool, I thought I'd be ok with out and it was too late to check other stores.
I might even still have it, if so you are welcome to it. I'd check your local part store, they should lend/rent it out (and that would have a nice handle, unlike mine which is raw steel)
1998 328ic - Sold
hockeyfan27 is offline   Reply With Quote
Old 03-25-2010, 11:55 AM   #9
mhamouda
Lookin like M
if ur in mississauga, ill lend you mine,
let me know when u need it
4165756057
mhamouda is offline   Reply With Quote
Old 03-27-2010, 12:21 PM   #10
exbmwtech
I bought a universal one at princess auto for $15-$20 (I think it said for chevys on the label) works fine used it many times.
exbmwtech is offline   Reply With Quote
Old 03-27-2010, 09:25 PM   #11
+1! Have been using the GM or Chevy one from Princese, was under $10...works great!
Old 03-28-2010, 08:13 PM   #12
proudbmwownr
borrowed it from mhamouda (thanks again) and no more coolant leaks for me
which princess auto ru guys talkin about, the one on dixie ? im pretty sure i looked there and didnt find it
Old 04-05-2010, 09:57 AM   #13
Darkness95m3
Darkness95m3's Avatar
I have removed mine on many vehicles.
My steps were;
1) liquid wrench
2) good hit with hammer on wrench
and off it comes.
