Old 03-20-2010, 02:15 PM   #1
Sunroof handle seized on sunroof gear arm
Stupid BMW. Its metal on metal. Its not rusted, but since the old handle was sheared off it doesn't look like it will come off clean. I let it sit in some penetrating lube all night and tried heating it up to no avail.
Anything else i should try before i take it to the shop?
TIA
Old 03-20-2010, 02:18 PM   #2
Ceeker
keep on the lube for a couple days. then gently tap with a hammer - vibration sometimes releases any rust or binding metal. you can also try good o'l elbow grease with a vise grip. Clamp it on good as you most likely will only get 1 or 2 shots at it.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 03-21-2010, 01:13 PM   #3
Heat works wonders for seized pieces. Get a wet rag and place it around an areas you don't want to get burnt and hit the handle with a propane or MAP gas torch. Tap with a hammer once its hot and it might pop off.
Old 03-21-2010, 11:02 PM   #4
Chisel + hammer = SUNROOOOOOOOOOOOOOOOOF!
