Old 03-15-2010, 03:10 AM   #1
Dysantic
Captain Chaos
Dysantic's Avatar
Calipers
So I am planning on doing a whole brake overhaul on my car. New rotors, new pads etc. I was wondering if it would be a good idea to replace my calipers as well since they are the ones that were most likely on the car when it was manufactured and they look pretty grimey.
Is it really necessary to replace them? If so, where can I go about getting some nice snazzy yellow or even black ones?
For a 1997 328i. I'd rather not have to do any kind of modifications to get the calipers on, just stock fitment.
Old 03-15-2010, 10:29 AM   #2
ScotcH
You can buy a rebuild kit for about $30 each caliper. If they are not leaking or sticking, there really is no reason to fix what aint broke. Check teh dust boots ... if they are cracked or brittle, I'd rebuild.
Old 03-15-2010, 10:46 AM   #3
simplycars
simplycars's Avatar
just clean them with some brake cleaner to remove the grime
simplycars is offline   Reply With Quote
Old 03-15-2010, 03:21 PM   #4
Dysantic
Captain Chaos
Dysantic's Avatar
Thanks for the info guys. I'll just give them a good cleaning and make sure the dust boots are intact. Just means I can spend more on the rotors and pads now. lol
Old 03-15-2010, 03:36 PM   #5
richie_s999
Pm'd
Old 03-15-2010, 08:29 PM   #6
Mad Cow
Just clean and paint them, they'll look new if you do it properly.
Mad Cow is offline   Reply With Quote
Old 03-15-2010, 09:24 PM   #7
Dysantic
Captain Chaos
Dysantic's Avatar
Is there any kind of special paint anyone knows of that would not fade or peel? I'm sure I'd need to use a certain paint on them.
Old 03-15-2010, 11:09 PM   #8
Mad Cow
Canadian Tire sells a kit by dupli-color, but you really need to do your prep work. I helped my friend do it a while back and it lasted a few months before it began to chip a bit, but I'm sure it would've lasted longer if we did everything properly.
You could also get them powdercoated if you have the cash, that will last forever.
Old 03-15-2010, 11:19 PM   #9
simplycars
simplycars's Avatar
BBQ paint - needs to be touched up every pad change for fresh look :-)
Old 03-16-2010, 12:24 AM   #10
Key is prep work! I spent a few hours (over several days) on mine, after they were fully rebuilt, used both primer and high temp paint...they are like new 2 years later including winter driving!
Old 03-16-2010, 12:39 AM   #11
aaron320i
Send a message via MSN to aaron320i
+1 for that, i also did this and it lasted forever.
aaron320i is offline   Reply With Quote
Old 03-16-2010, 03:19 AM   #12
gotcurry
burble city
gotcurry's Avatar
what rotors n pads r you planning on using??
gotcurry is offline   Reply With Quote
Old 03-16-2010, 03:23 AM   #13
Dysantic
Captain Chaos
Dysantic's Avatar
I'm not sure on either the rotors or the pads right now, I'm still looking around. I really just wanted something that will last, looks good and isn't ridiculously expensive.
Old 03-16-2010, 12:56 PM   #14
gotcurry
burble city
gotcurry's Avatar
I did my pads and rotors a week ago. I went with drilled zimmer man rotors and wagner pads. Looks good and breaks good. I cant comment on prices cus i get shop price and i do the labour my self but this set up should not cost u much.
Old 03-16-2010, 02:23 PM   #15
Dysantic
Captain Chaos
Dysantic's Avatar
What kinda paint and primer did you use Fil? I don't really have several days to do this, just hopefully one day to take all the wheels off and then the calipers and paint them. So it may not be that long of a timeframe, but maybe I can squeeze what you did into a day or maybe two. lol
