Old 03-12-2010, 01:41 AM   #1
FU*K YOU BELL CANADA (Bell throttle inside)
I'm sure this wont last long, but the nerds at utorrent figured out how to bypass the bell throttle using UTP connections.
All this goodness is included in the recently released utorrent 2.0
I've been getting around the throttle for 2 days now. Wont get close to my advertised speed (8mbit) or my usual max speed for http transfers (850kb/s) but i get 250-300kb/s stable throughout the day (when i should be throttled.)
Lets hear a nice **** you to m@bell.
(Note: With utorrent 2.0, all DSL customers in ontario (everyone on bell copper that doesn't have non-pppoe login) will be able to get around the throttling. This means acanac, primus, teksavvy, etc.)
http://www.utorrent.com/downloads
Old 03-12-2010, 10:14 AM   #2
StikiGreenZ
StikiGreenZ's Avatar
Thanks for the info... downloading now
BMW 645i - Black on Red
Old 03-12-2010, 12:36 PM   #3
arek
nice, im downloading the crazies.
Usually, I get my mother to download movies for me, not only does she have unlimited bandwith, but she downloads at speeds in the excess of 500+kb. She is using Primus, which i believe is branched from BELL! Funny.
I have bell. downloading @ 500kb/sec right now.. wowzers.
arek is offline   Reply With Quote
Old 03-12-2010, 04:22 PM   #4
Junaid
my primus gets me around 300 kb/s too
Needs more mods
Junaid is offline   Reply With Quote
Old 03-12-2010, 04:24 PM   #5
Furious
BMW again.
Furious's Avatar
im not throttled
Old 03-12-2010, 04:31 PM   #6
Originally Posted by Furious View Post
im not throttled
Tell bell to get their shit setup in Ajax. I want to switch to Bell fiber 25.
Old 03-12-2010, 05:07 PM   #7
mirek
mirek's Avatar
only 500kb/s? I download using my Shaw extreme at 1.8MB/s ...
Old 03-12-2010, 08:29 PM   #8
NOTORIOUS VR
NOTORIOUS VR's Avatar
only 1.8MB/s? I DL @ 2.95MB/s
w/ Rogers Extreme Plus
Old 03-12-2010, 10:02 PM   #9
SamE30e
SamE30e's Avatar
I have Bell and I download at like 20kbps anyone care to shed some light on getting around this?
I have the latest version of u torrent.
85 325 - Turbo M52B28.
Old 03-12-2010, 10:19 PM   #10
steve.325i
I'm lucky to hit 1.1MB/S with my rogers extreme .... hmmmm.
steve.325i is offline   Reply With Quote
Old 03-12-2010, 10:36 PM   #11
That is actually the max speed since extreme is only a 10Mbit connection.
Extreme plus is 25Mbit.
Old 03-12-2010, 10:48 PM   #12
steve.325i
Ah, I missed the 'plus'. I though the Extreme was rate for 10Mbit/s.
Thank you.
Old 03-13-2010, 02:05 AM   #13
2slow2race
2slow2race's Avatar
i got the rogers express at 10Mbit connection, and i go 1.2MB/s steady.
thats weird for you. get it checked out.
NOTORIOUS VR, damn! thats like zero wait for tv shows and movies.
games in under a hour. solid!
2slow2race is offline   Reply With Quote
Old 03-13-2010, 03:11 AM   #14
SamE30e
SamE30e's Avatar
Anyone want to help?
Old 03-13-2010, 05:33 AM   #15
sam,
Press Ctrl+G in utorrent and run the test. make sure that a port is forwarded correctly. (TCP & UDP)
If you are using windows 7:-Disable disk cacheing (just disable all of it, its under advanced in pref's.)
-Run the program as administrator & comp mode for vista.
Also, for my content fiends:
Basically what UTP does is detect network congestion (between peers A+B) by comparing pings. It then throttles itself down to just below the level where network congestion is caused. This is NOT how it gets around the throttle. This IS a reason why bell may let this go (for a while). This means that torrents will no longer choke out other network traffic when uncapped *hard caps available for up/down in settings*.
This also means utorrent isn't even trying to achieve max line speed. **** that.
In order to maximize your DSL link, run two instances of utorrent (2nd instance has to be non-UTP bittorrent client. This means the 2nd instance can't be utorrent 2.0 (but can be 1.91A and older.) Some older versions still accept UTP transfers, but do not initiate them. Any further UTP traffic on the network will affect the first instances speed, therefore it I currently recommend turning UTP connections off entirely on the 2nd instance.) I haven't tried running both instances on the same machine, although this is likely possible. (remember to portforward for both instances, each needs its own port)
Remember, the 2nd instance (non-UTP) wont throttle itself at all. You will want to put a hard cap on both download and upload speed otherwise torrents will be eating up all your bandwidth. Also, since even incoming UTP connections aren't allowed for the 2nd instance, the traffic will be 100% throttled (but UTP wont detect this traffic, so at 30kb/s you can download an additional 1.1 gb in the 14 hours you are throttled a day).
Remember, if you have ADSL, your up speed will inversely affect your download speed. Make sure no instance of utorrent is uploading at more than 20kb/s. (mine are at 6kb/up per instance)
I seem to be getting 250kb/s through UTP (throttled) and 375 unthrottled, and 30kb/s non-utp (throttled) and 500 kb/s (unthrottled).
That's 45 gigs a day theoretical download limit. I will probably scale everything back 20% to free up some bandwidth for everyone else in my house who needs internet. Still enough for 2-3 1080P rips a day, just need some more
I'm happy, and i still hate bell
Doogee, dont get fibe, its pointless. The cap is like 80 gb. I should be able to hit that in 2 days with my simple 8/1 sympatico ADSL profile.
