Old 03-10-2010, 05:24 PM   #1
b-dawgGTA
worth doing these mods?
Hey guys, back in the game again now that summers around the corner. Bimmers comin out soon
so for this year im planning on dropping her for sure and hopefully a chip. I would like to look into a upgraded steering rack and a higher ratio diff. Im wondering if either of these will make a big difference. I was thinking a m3 rack and a 318 auto 4.45 diff(if thats correct)
So any info on those to mods from people doing them or if they like it or not would be nice.
PS not going to swap it, so dont even say it lol she only has 168k and runs like a charm
cheers guys
Edit: figured Id add a pic of her from last season
- 91 318is
b-dawgGTA is offline   Reply With Quote
Old 03-10-2010, 06:23 PM   #2
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
By all means, change the rack... as far as the diff goes, it's a 4.44, but is it a LSD? if not, just keep your 4.10LSD, or look for a 4.27LSD.
Grow up and move on.
Old 03-11-2010, 01:00 AM   #3
E30 Kid
Send a message via AIM to E30 Kid
i have springs and shocks for sale (60/40 drop)
Stretch. Poke. Flush. Stance Matters
Family Tree: 318is, 323i, 325i, 328i, 540i
E30 Kid is offline   Reply With Quote
Old 03-11-2010, 10:41 AM   #4
gervs
gervs's Avatar
I have a 318, and dropped it, putting a z3 rack in next week and going to follow this guide to liven up the m42.
http://bmwnut.blogspot.com/2006/04/1...ance-mods.html
I contemplated a swap several times, but decided to keep it light weight in the end, and just take driving lessons. These cars are made to be driven by someone who knows how to drive it around the track. That's when you see the true potential of what a slow 4cyl lightweight 318is can do.
Car looks super clean though. I wish my paint looked like that still! I might suggest US or Euro ellipsoids. I can actually see at night now!
gervs is offline   Reply With Quote
Old 03-11-2010, 11:27 AM   #5
SamE30e
SamE30e's Avatar
A 4.44 diff would be useless. You pretty much would have no first gear, and be at like 4750rpm at 100km/h.
85 325 - Turbo M52B28.
Old 03-11-2010, 12:26 PM   #6
richie_s999
you want to find a 4.27 diff, not easy but worth it, and get a Mark D chip, he's on the baord, just go with an e36 rack, its a lot cheaper and easier to find then an M3 one, and only .2 turns different. Stay away from the z3/4 rack, only reason its shorter is cause it doesn't actually turn as much as an E36 one.
my e30 should be out storage in a bit, if you want a ride to see how the mark d chip and 4.27 diff are, come to the april 11th auto cross, there will be a few other 318is cars there with slightly different mods, you will get a chance to see how they all do.
Old 03-11-2010, 09:58 PM   #7
b-dawgGTA
found good info on the rack swap, read about the 4.27 sounds way better than the 4.44 lol.
sounds sick ill be at the auto cross hopefully
- 91 318is
Old 03-11-2010, 10:52 PM   #8
b-dawgGTA
question about the steering rack, all the swap ive found have been done to no air bag cars. It seems you need to make a custom bracket to make it work with a air bag. If i remove the air bag do i need to do this
- 91 318is
Old 03-12-2010, 02:38 AM   #9
nonlocal
Last of the Late-Brakers
nonlocal's Avatar
I did some reading after we talked about this at Downsview, and I believe this is not quite correct. The 2.7 turn z3 rack *does* turn less, but that's not the only reason it's faster. It is just as fast as the '95 M3 rack, but you get less final wheel deflection, hence the quicker lock to lock. So Ideally a '95 M3 rack, but if you are tracking the car a Z3 rack is just as good... if you are doing U-Turns in the city and tight autocross circuits the 3.2 turn e36 rack might be better because you get a tighter turning circle than the z3-- but not quite as quick a ratio. Dig?
I have no solid sources for this on hand but thought I would pipe up anyway.
Old 03-12-2010, 10:34 AM   #10
richie_s999
from what i have been told they are the same racks, just the stops which control total distance traveled are different resulting in 2.7 turn instead of 3.2turns. same speend less distance traveled
Old 03-12-2010, 10:46 AM   #11
gervs
gervs's Avatar
If you have an airbag car it's a direct swap, except the firewall needs to be dremeled.
See the bottom section of this article.
http://www.rmeuropean.com/bmw-e30-steering.aspx
EDIT* Not direct swap, you need 4 spacers on the mounts.
Old 03-12-2010, 11:37 AM   #12
supernaught
supernaught's Avatar
try putting one into an iX
Old 03-12-2010, 07:22 PM   #13
E30M42cab
E30M42cab's Avatar
I respect all you IX guys for all the shit you have to put up with on your evil freak cars.
Old 03-12-2010, 09:00 PM   #14
shanehutton
So any E36 rack will bolt right in, that's good news. I have a couple of questions though:
1. which tie rods do you use? Are they the same or do you have to use E36 or E30 inners and outers?
2. Do you have to shorten the steering knuckle or does it just move the wheel a bit closer to the driver? I am doing the swap in a race car so I may be building an adjustable slotted mount at the wheel end to adjust the wheel height. If I just need to compensate for the length there then I may leave the knuckle alone.
shanehutton is offline   Reply With Quote
Old 03-12-2010, 10:06 PM   #15
b-dawgGTA
to answer 2, you have to make spacers to make the knuckle fit. wheel should be in same spot. as far as i know from what ive read
- 91 318is
