Old 03-07-2010, 10:40 PM   #1
INFAMOU$
Automotive Puppeteer
INFAMOU$'s Avatar
Question E46 330 Seats into an E36? Answers please...
A good friend of mine was nice enough to hook me up with a pair of 330 coupe seats which are power and heated. Just wondering if these bolt in to an e36?
Some say you need to weld a plate then bolt in.. others say to hone out the holes.. Anyone ever try this? I have searched but don't have enough time and need some direct answers.. Otherwise I will wait until after the show.
If anyone has the wiring info for the e46 seats that would be great too as they will need power to move!
Old 03-07-2010, 11:11 PM   #2
Your friend doesnt happen to work (at/close to) Stark auto? Set of black coupe seats "went missing" from a car i got there...
Old 03-08-2010, 10:00 AM   #3
INFAMOU$
INFAMOU$'s Avatar
No he has had them for years from an upgrade he did...
Old 03-08-2010, 10:11 AM   #4
euroguy
euroguy's Avatar
I installed a pair E46 coupe seats (sports/power/lumbar/non-heated) into a E36 sedan. Didn't have to weld anything, holes lined up properly(no welding,no cutting,no drillin), used the bolts from the e36. Power/lumbar functions worked, power wire was spliced into the first constant power that I found, don't remember where exactly. Seatbelt recepticles you had to play around with a little bet to make them work. I had to remove the side handles on the top bolsters from the seat though as they were touching a little bet on the side but that's because the e36 was a sedan.
Goodluck.
euroguy is offline   Reply With Quote
Old 03-08-2010, 11:04 AM   #5
INFAMOU$
INFAMOU$'s Avatar
Goodluck.
Great to hear! I will try swapping them in for the show then.. Did your seats have the Memory settings and all that on the drivers side? I don't care about the heat.. just want the power to work..
Old 03-08-2010, 11:17 AM   #6
JazzM
e46 seats bolt right up to an e36. Including e46 M3. For power to work, you just need to wire up the ground and the power. For the sensor you can either wire up a resistor or transplant the occupancy sensor from your donor seat.
Another option are the z3 M roadster/M coupe seats (also used as sport seats on the Z4):
T.
T.
Old 03-08-2010, 11:43 AM   #7
INFAMOU$
INFAMOU$'s Avatar
Anyone have a diagram of the clip for under the e46 seats for the power?
Old 03-08-2010, 04:22 PM   #8
theblue
old school US member.
theblue's Avatar
Send a message via AIM to theblue
E46 seats do NOT bolt right into an E36, but it is close. I have E46 sports seats in my E36. You have to file forward from the rear seat holes until you can get the bolts to go in. The seat belt clips right into the E46 seats without any modification. Getting the power functions to work is as easy as adding power and ground, but I do have an airbag light since I haven't been able to figure out how to wire that part in (and I've done a lot of research on this).
see this thread for more info:
http://forums.bimmerforums.com/forum...d.php?t=395727
my seats:
08 Corvette LS3 // 89 325is w/ M50 swap // 06 Audi A3 (stg 2) // 07 VW EOS (stg 2) // E36 Chumpcar
theblue is offline   Reply With Quote
Old 03-08-2010, 04:38 PM   #9
INFAMOU$
INFAMOU$'s Avatar
my seats:
LOL I actually read your thread and that's where i got the info about having to file the holes!
Thanks for the info.
Old 03-08-2010, 04:43 PM   #10
euroguy
euroguy's Avatar
I have to disagree here. When I personally installed the seats, didn't have to file or anything. Bolted right in, which I was even personally surprised.
This shouldn't make a difference but my seats came out of 2003 330 coupe and went into 97 sedan.
Lumbar worked as soon as power was connected, memory settings we didn't play around with.
Old 03-08-2010, 04:52 PM   #11
JazzM
Yeah, I had the same experience... perhaps the donor seats that were used had a bent track on them.
From my experience (e46 m3 seats in 328i) they bolt right in.
T.
T.
Old 03-08-2010, 07:01 PM   #12
theblue
theblue's Avatar
weird... you guys are the first I've heard that where able to bolt the seats right in, and I've read a lot of write ups.
I'd have to see it to believe it.
Old 03-08-2010, 11:33 PM   #13
INFAMOU$
INFAMOU$'s Avatar
I'll let you guys know on Wednesday when i bolt them in.. I found the power and ground wires so all should be very straight forward.
Old 03-13-2010, 03:47 AM   #14
JetBlackE46
perhaps there are minor differences between coupe/sedan/convertible?
JetBlackE46 is offline   Reply With Quote
Old 03-13-2010, 05:37 AM   #15
doogee
doogee's Avatar
Witnessed this myself!
Dakar M3 Track Build Thread
