Old 03-07-2010, 09:51 PM   #1
JINT
JINT's Avatar
Cluster lights out, help
Anyone knows a reason why would the cluster lights die, and also all the bulbs that light up the buttons in the car? the fuses are good and bulbs aren't burnt. Could it be a bad fusebox?
Old 03-07-2010, 10:49 PM   #2
mhamouda
Lookin like M
no other lights are out.. ur tail lights?
mhamouda is offline   Reply With Quote
Old 03-08-2010, 08:02 PM   #3
JINT
JINT's Avatar
right tail light is out as well, bulb is good. Break lights work tho
Old 03-08-2010, 08:51 PM   #4
tg07lq
all the dash lights are out ?
4cyl autotragic woes...
tg07lq is offline   Reply With Quote
Old 03-08-2010, 10:35 PM   #5
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
Could be the fader in the headlight switch... if it fries, the interior lights go out, other than the glove box light, and maybe one other.
Grow up and move on.
Old 03-08-2010, 11:10 PM   #6
Brent
Brent's Avatar
There is a recharable battery that powers the circuit board. It is found behind the dash. Often these batteries seem to leak, and when they do, they short out the boards. This would definitely cause an issue with the lights on your dash (I know, half my dash lights and instruments weren't working, then I replaced the circuit board and everything worked right away). The explanation above seems a little more likely, but if that doesn't work, at least you have another option...good luck!
Brent is offline   Reply With Quote
Old 03-09-2010, 03:27 PM   #7
Smitty
Smitty's Avatar
I had the same problem a few months ago. It turned out that the headlight pull-switch was the problem. The cluster and dash lights would only come on if I yanked up (hard) on the switch while pulling it. Popped in a new switch and solved the problem.
Some old BMWs
Smitty is offline   Reply With Quote
Old 03-10-2010, 01:49 AM   #8
e30STONES
check your fuse box homie, 7.5A. I had the same issue. I had water leaking from a taillight shorting out my parking light(front and back) and the interior light+cluster.
e30STONES is offline   Reply With Quote
Old 03-13-2010, 11:09 AM   #9
JINT
JINT's Avatar
thanks for the replies, alot of useful info here. The rear right tail light is out, as well as front right parking light too. I'm gonna start checking all these shits.
P.s. Brent is it hard to get to that battery behind the dash?
