03-05-2010, 08:24 PM
#1
Is now married :D
Car: 330ci Cabrio
Need plummers advice
Ok, enbridge recently came into my house to change out my old water heater and replace it with a new one.
Shortly after they left I noticed a small leak coming from one of the faucets that has a small pipe running to the water heater and some thing else.
They came back to look at the leak and told me that its coming from the main house valve and that this valve has nothing to do with them and that I have to call the city to shut off the water to the house so that the faucet came be changed out by a plummer at my cost.
What is this bs? 14 years without any issued and now enbridge comes in and fu*@'s thing up!
It leaks like one drop every few seconds and is starting to make a puddle.
My question; Is there a way that I could get this valve changed without getting the city involved? Can a avarage plummer do this type of work for me and what is the costs accosiated with it?
Any input would be greatly appreciated.
03-05-2010, 08:49 PM
#2
Car: 4 wheel
Hope this helps abit... if it is the main valve, it has to be shut off from the main water supply and a plumber can do this kind of job...check out the link
http://homerepair.about.com/od/plumb...er_shutoff.htm
03-05-2010, 10:54 PM
#3
Car: 325i, 335xi
These valves have a tendency to suddenly start leaking if they've haven't been used for years. Especially if they contain internal rubber parts. Sometimes, you can stop the leak by readjusting the tightness (as tight as possible is not always best). When putting in a new shut off valve, I think that a ball valve is recommended because it is less likely to fail since there are no internal rubber parts.
03-05-2010, 11:08 PM
#4
Car: 325i, 318is
^this
enbridge would have shut off the water and the seated rubber seals probably tore, you could try and do it yourself haha, just gotta be quick about it! (i kid)
gotta have city shut off and get someone to do it. its pretty easy job if you have basic mech skills, but cause its a main your probably better off paying someone ( no room for trial or error)
4cyl autotragic woes...
03-06-2010, 12:31 AM
#5
Is now married :D
Car: 330ci Cabrio
Definitely not some thing that I would attempt myself.
Thanks for the input, keep it coming.
03-06-2010, 12:41 AM
#6
Driving in the fast lane
Car: e38 Sport, e63
When the city comes and shuts off the main and you only need to replace the washer, have the crew stick around for a few minutes so that you can have it turned back on or you might have a to wait awhile to have them return to turn it back on.
If you're hiring a plumber I'd have him install a ball valve prior to the meter in addition to replacing the (synthetic) rubber washer. Valves are pretty inexpensive.
'04 645cic (for sale)
'05 GMC Sierra SLT Z71 CCSB 4x4
'02 Regal LS
'00 740i Sport
'06 330cic vert ZHP (sold)
'00 323i (sold)
'99 328cic vert (sold)
03-06-2010, 08:30 AM
#7
King Sirex
Car: VW
he probably does not have a water meter.
well anyway, if youre shutting off your water, unless you call in an emergency, the city is probably gonna take a while to come and shut it off. so be prepared to be without water for a long time.. specially if they leave so taht you can get work done.
definately get a shut off valve installed... specially if there is old plumbing in your house, you never know when it might come in handy. they should also install a release valve with the shut off valve.
------city water ------------------ shut off valve ---- release------------------ home
so if you shut off youre water, by opening the release all the water in the house should clear out though that valve, more or less.
the parts are mostly inexpensive - for the most part, but the tools are expensive, and so is the work.
Youre probably looking at a total of 200$ to 400$ to get both problems fixed. Thats a pretty wide estimate, but thats how most of these trade people operate.
03-08-2010, 03:44 PM
#8
Car: 94 318is N' 95 ///m3 luxury
Looks like its the packing nut on the valve, simple fix (no need to call city) look at the the stem of the valve handle, you will see a hex shaped nut, first close the valve, and tighten the nut, not too much or you will not be able to reopen the valve, then slowly open and your fine. Most valves do this, even when putting in a new valve. Most cases this happens when the valve hasnt been closed in a while so when someone closes it no leak but when re-opened you have a tiny leak.
