Old 03-06-2010, 03:15 PM   #16
ultimateX5
Ally04
ultimateX5's Avatar
I'm gonna try to pressure bleed fromthe bottom,I have a feeling the mastercylinder by the Pedel isn't keeping the pressure because the slave is fine. If all fails I'll change the master.
garage :
08 x5 4.8- totalled(got tboned)
93 e36 sedan - sold
10 dodge ram
03 acura mdx
94 dodge ram cummins
00 ford f350
00 dodge dakota
87 e30 325is Mtech
97 e36 328is Mtech'd
98 e39 540iMtech
ultimateX5 is offline   Reply With Quote
Old 03-06-2010, 06:24 PM   #17
ultimateX5
Ally04
ultimateX5's Avatar
Finally got it! Had to pressure bleed it from the bottom. Here's what I did!
1. Took an empty brake fluid bottle, cut it in half.
2. Took an old fuel pump that I had lying around, got
a rubber hose and connected it to the "out" side.
3. Placed the pump into the bottle.
4. Put the rubber hose onto the bleed nipple and slacked it.
5. Bunjee tied the clutch pedel up
6. turned the pump on and waited till the brake fluid resovoir started to run over.
7. Tightened up the bleed nipple, took off the hose and BAM! the clutch was back!
Thanks for your help guys!
found New issues!
there's a little pump underneath the car right by the drives side rear wheel, that's leaking fuel like crazy!
Rear brake lines are rusted.
Car has a missfire, bad injector? Time for M50 injectors?
And thermostate need changing! Hopefully that's all. Cuz I really dont wanna spend more
money on this car. Probably gonna end up selling it after I fix all the little things.
That's it for now. I'll post pics of the car tonight! Hopefully I can hit the first e30 meet and still be in decent condition!
Thanks again!
garage :
93 e36 sedan - sold
10 dodge ram
03 acura mdx
00 ford f350
00 dodge dakota
87 e30 325is Mtech
98 e39 540iMtech
Old 03-06-2010, 09:35 PM   #18
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
Yeah, or you could have put it on the same way it came off, which means the bleed screw is on the top of the cylinder.... hence all the fluid fills up the cylinder, air comes out the top, until the brake fluid comes out... no more air = clutch working. Just like a brake caliper. Anyways...
Grow up and move on.
Old 03-06-2010, 11:23 PM   #19
ultimateX5
Ally04
ultimateX5's Avatar
There was no way this slave would fit the other way..the old one was facing down and when I tried to put it facing up because it makes more sense being up..the line would hit the tranny and it wouldn't bolt up..I didn't feel like getting another line made up..I don't know if someone did it before and switched it up cuz it's my first time doing one on am e30..but I'm just glad it works!
garage :
93 e36 sedan - sold
10 dodge ram
03 acura mdx
00 ford f350
00 dodge dakota
87 e30 325is Mtech
98 e39 540iMtech
Old 03-07-2010, 12:24 AM   #20
TopSpeed
TopSpeed's Avatar
I have the same issue with my clutch now. I was actually going to post a question about it.
The bleeder is located facing down, that I know for sure.
Are you absolutely sure the rod is sitting in the "Divot"?
Does the slave cylinder have any special way of going in? It seems like I have pressure and it bleeds just fine but my pedal only comes back half way and that's it.
TopSpeed is offline   Reply With Quote
