Go Back   maXbimmer Forums > maXimum Tech > 6/8 series
Old 03-03-2010, 01:33 PM   #1
Boxer2
The OPP loves my M5
Boxer2's Avatar
Question Separating shock from rear trailing arm
Hi guys, started doing some suspension work on my E24. I'm in the process of deleting the self level system, and at the point were I must disconnect the lower portion of the shock from the mounting point on the rear trailing arm. I have removed the large bolt holding it together and still dose not want to separate. I even tried a little persuasion with a hammer and large punch as well as with a couple of pry-bars but it hasn't even moved.
am I doing something wrong here, did I miss something?
Any help is greatly appreciated.
cheers
Rene
My Garage:
1986 328is (M20 Stroker)
1986 535i (5sp all original)
1990 325iX (Mint 5sp all original)
1989 325iX (Winter auto X car)
1991 M5 x2
1988 M6
2001 740i (Supercharged)
1999 528iT (summer DD)
2004 X5 3.0i (winter DD)
Boxer2 is offline   Reply With Quote
Old 03-03-2010, 09:13 PM   #2
nachos23
SweetXi
nachos23's Avatar
Nope. Keep pursueding! Its a compression fit. Take a screwdriver and SLIGHTLY pry open the end where the bolt went through and try again.....
My Rides:
2009 335Xi
520HP
H&R coilovers
BBS LM wheels
//M sport package
BMW Personal Audio System
2000 Z3M
Conforti tuned
AFE CAI
++More to come this winter
Old 03-04-2010, 03:22 PM   #3
Boxer2
The OPP loves my M5
Boxer2's Avatar
Problem solved, ended up pulling the trailing arm and shock assembly in one piece, then I shoved a large drift punch into the hole where the shock connected to the trailing arm making sure not to go in to far and damage the inner threads, and then just hit it from side to side a few times and out it came
My Garage:
1991 M5 x2
1988 M6
