Old 03-02-2010, 08:42 PM   #1
dil
dil's Avatar
Oil Pressure light !!
how do i diagnose this problem?
the oil level is fine just recently did the cylinder head and all gaskets did full synthetic oil change added some engine restore to oil
What cud it bee ?
dil is offline   Reply With Quote
Old 03-02-2010, 09:16 PM   #2
ScotcH
On all the time, or just at idle? If on all the time, either the sensor is dead, the wiring is faulty, or your oil pump died (or the pump nut fell off). I would not run the car until you determine what the issue is!
Old 03-02-2010, 09:33 PM   #3
dil
dil's Avatar
it flickers wen the car is in idle with warm oil only not on cold starts
Old 03-02-2010, 09:47 PM   #4
BMW_M_POWER
740il
BMW_M_POWER's Avatar
this exact problem was in my 96 honda before I bought it, the seller claimed it was minor/next to nothing. The light use to go on and off after idle, two days later the engine started ticking and got to a point it sounded like pop corns. I decided to take the engine apart and found the piston 1 bearing the done.
but in your case it could be the oil pressure regulator
SOLD 04 ///M3
BMW_M_POWER is offline   Reply With Quote
Old 03-02-2010, 10:20 PM   #5
blk3
blk3's Avatar
what oil weight you using? how many clicks on the motor? could be a weak oil pump, too much clearence in your bearings or a weak oil pressure switch. the switch is the chapest part, better hope its that
Old 03-02-2010, 10:21 PM   #6
dil
dil's Avatar
i use 5w30 and added a bit of engine restore to thickin it
shud i replace the switch and see Wat happens
wer is it located
Old 03-02-2010, 10:36 PM   #7
blk3
blk3's Avatar
personally i use 10w30. if you want to thicken the oil a bit use lucas. that stuff works good. you can try replacing the switch since they are cheap. not sure of the location but you can probably do a search on here or online to find its location
Old 03-02-2010, 10:47 PM   #8
blk3
blk3's Avatar
check for the oil pressure switch behind the oil filter housing in the lower area of the unit. i could be wrong but it should be around there
Old 03-02-2010, 11:54 PM   #9
like I posted in your other thread
From the E36 owners manual:
Although it would probably bother me too which I why I can understand that you want to make it go off completely.
Old 03-03-2010, 12:40 AM   #10
aaron320i
Send a message via MSN to aaron320i
Listen for knocking. If one of your crank bearings are gone there will be a loss of pressure.
As mentioned by BMW_M_POWER.
aaron320i is offline   Reply With Quote
Old 03-08-2010, 11:48 AM   #11
E30Rider
E30Rider's Avatar
Send a message via MSN to E30Rider
i think you might need an oil pressure switch for sure, i'ved had the same problem with my E30 and soon as i know my light came on for good and my pressure switch was leaking oil.
E30Rider is offline   Reply With Quote
Old 03-08-2010, 02:07 PM   #12
JazzM
I think you're using the wrong oil. BMW approves only the use of ACEA A3, BMW LL-98 or LL-01 rated oils. A lot of 0w-30, 5w-30, and 10w-30 are not approved at those ratings (synthetic or not).
My suggestiong would be to use Castrol Syntec 5w50 during winter time and 20w50 in the summer. They are ACEA A3 rated oils.
T.
T.
Old 03-12-2010, 10:45 AM   #13
Eurotakeover
BMW Obsessed
Eurotakeover's Avatar
same with my friends M3, it was the oil pump
Eurotakeover is offline   Reply With Quote
Old 03-14-2010, 01:17 PM   #14
Darkness95m3
Darkness95m3's Avatar
It could be all of the above and then some.
These are the best steps to take, from cheapest to most expensive.
1) go with heavier grade oil.
2) Test the sensor, borow one from someones car that wworks, would be your best bet.
3) Your oil pump might be worn out.
4) You have a bad bearing, meaning to much of a gap between the bearing and crankshaft.
5) Take it to your BMW dealer.
