03-02-2010, 11:55 PM
#16
How do i shift gears?
Car: waiting to find out?
Originally Posted by Mad Cow
Seafoam is just a good if not better, and Napa sells it for around $10 a can around here, partsource had it for $12.
In my beater there is a slight hesitation at 2500 rpm. Do you think seafoam would help this?
03-03-2010, 11:47 AM
#17
Car: 1997 328i
It could, and if it doesn't all you wasted was 10 bucks.
03-03-2010, 01:02 PM
#18
Singhy
Car: '98 323is
Originally Posted by aaron320i
Does the VR6 have plug wires? I would bet on them if the car is equipped with them. If not check for a broken vaccum line.
yes it does. He says that they were recently replaced, and there is a spark at each cylinder (i tested that). I also checked all the vacuum lines and hoses around the engine bay as best I could and found nothing wrong with them, although the age is beginning to show on most of the rubber. Like Mad Cow said, I'm willing to throw $10 on this car if there's a chance it could fix it. If not, its back to square one. BTW I dont think this affects the hesitation, but there is a "whining" noise from the engine, sounds like a belt or pully going bad IMO. Other than that the everything looks good on paper.
03-04-2010, 12:01 AM
#19
Car: 01 320i mpackage
Well I was just putting a Mazda back together form an engine swap and I drove it out and the car ran beautiful. Went up the street opened it up a little and then I started having problems. I get back to the shop and scan the car. Cylinder 3 misfire. Fackkk. OK well I checked everything. Except for the wires. I was told by the owner that the car just had a full tune up 2 weeks ago and that everything was changed, fuel filter, plugs, wires, pcv,air filter... blah blah blah. I ended up replacing the wires, no further problems.
The old ones even looked newer than the new ones.
03-04-2010, 01:52 AM
#20
Car: Budget Ballin' e36
Anyone? My cousin's jetta VR6 won't stop hesitating and sputtering (doesn't fully stall). We checked out everything we can think of (plugs, injectors, cleaning intake system/throttle, checking the o2 sensors, new gas). I thought I'd give the seafoam a shot (plus I get to test it out before using it on my car).
I'm willing to bet its a bad coil pack as I've also had this problem on my vr6.
Get one of those spray bottles for plants and lightly mist around the coilpack when the car is on, If you see arching around the where the wires connect to the coilpack. Its the culprit.
The bad news, Coilpacks go for $350 new.
03-04-2010, 02:28 AM
#21
Car: E38 BMW 740IA
^^ had same problem with my VR6
got used coil pack for $100, worked fine.
BMW E39 540 MSport
BMW E38 740IA - Sold
VW MK6 Jetta TDI - Sold
BMW E39 540IA - Sold
VW MK4 VR6-Sold
03-04-2010, 07:21 PM
#22
Singhy
Car: '98 323is
yikes....$350 seems insane. I would hate to be wrong. I'll try misting it to see if I get an arc.
03-05-2010, 12:41 AM
#23
Captain Chaos
Car: 1997 328i
Originally Posted by Nguyen_E30
brake booster, oil cap and gas tank
So wait, you just take off your gas cap and spray this stuff in the tank? Same thing with the oil tank? Or am I just misunderstanding something?
03-05-2010, 03:30 PM
#24
Singhy
Car: '98 323is
There's a video of someone using this on their e36 on youtube. It shows the procedure pretty well.
03-05-2010, 03:38 PM
#25
Stuff like seafoam is only a temporary fix. The problem may get worse if you don't fix it properly.
03-05-2010, 03:46 PM
#26
Heo Quay
Car: E30/E36/E90
yeah, youre supposed to pour 1/3 in brake booster, 1/3 in the engine and 1/3 in the gas tank. let it sit for about 10 mins and then start her up. let her idle for a bit and than rev her up and drive her for a bit.
tons of vids on youtube
03-05-2010, 05:59 PM
#27
Car: 325Ci
Guys....if you pour this stuff in your vacuum boost line or in your intake, do it before you change your O2 sensors and your spark plugs!
Also, if you pour it into your oil, do it before a oil change!
This stuff works great, but it will mess up your O2s and sparks with all the gunk it burns off!
03-05-2010, 09:41 PM
#28
Car: BMW 540i
^+1 on that. Oil change is recommended after seafoam. All the build up thats being flushed out by it may/will damage O2 sensors and may also clog up catalytic converters.
Some tried it on here and say its good.
E39 540i Sport
03-06-2010, 01:04 AM
#29
Captain Chaos
Car: 1997 328i
03-06-2010, 07:58 AM
#30
Car: 325Ci
Also...use the deep creep spray version if you going to put it into your vacuum boost line and go slow, if you use the bottle and pour it too fast, you can hydro lock your engine...dont let it stall.
